RS100 wiring loom
Replied by Gr8uncleal on topic RS100 wiring loom
I'm not for one moment doubting his capability but, if it is a model that had no regulator fitted as standard, he might not know that Yamaha recommended retro fitting of these. I have attached a link to the Yamaha Service Bulletin on this subject.
Was it the rectifier or regulator that was changed?
Vintage Yamaha Enduro Fans - Service Bulletin #M5-084 re Voltage Regulators
19 Mar 2025 04:55
#11
- Welshboy
Replied by Welshboy on topic RS100 wiring loom
Thank you I will check.
I am told my bike is a 1978but possibly only registered then.
would my bike have a VIN as all i have is matching frame and engine number
19 Mar 2025 05:03
#12
VIN is just another name for the frame number.
Matching is good - it means the engine hasn't been replaced.
19 Mar 2025 05:09
#13
No promises, but if you post here the first 6 characters of the frame/engine number, then we'll try and give a steer on which model you have.
Your numbers probably start with an asterisk, then 3 characters, then a dash, then 6 or 7 more characters, then another asterisk. What we need is the 3 characters each side of the dash.
19 Mar 2025 05:16
#14
I meant to ask, is your voltage spike causing bulbs to blow? If yes, what happens if you fit a 12v headlight bulb?
Does your bike have a magneto set up, or generator/alternator?
19 Mar 2025 05:33
#15
- Welshboy
hi, the only number i can find on both frame/engine is 102271
just got a 12v to try.
19 Mar 2025 05:49
#16
There will be other characters in front of these, followed by a dash - might need a rub clean!
Here is a random example from fleabay - look at photo number 13 to see what I mean.
GENUINE YAMAHA RS200 1980 COMPLETE CLEAN ENGINE | eBay
- Welshboy
found the plate 1Y8 102271
it has a stator plate and new regulator on headlight.
12v bulb blowing.
its peaking around 100v on revving - conclusion wiring oxidised.
12v bulb blowing.
19 Mar 2025 06:24
#18
OK.
Can't be absolutely certain, but probably a 1977 model.
19 Mar 2025 07:07
#19
- Welshboy
thank you
19 Mar 2025 07:36
#20
