What carb specs for 1977 DT250?
  • mjf6866
  • mjf6866's Avatar Topic Author
What carb specs for 1977 DT250? was created by mjf6866
Hi guys, can anyone tell me what model Mikuni goes on a 77 DT250?  I might purchase one that is missing the carb and I can’t get concrete info on finding one one eBay or maybe another one that would work.  If anyone has any pics of their up close that would really help me when I’m searching at swap meets.  Thank you!
31 May 2024 19:09 #1
Replied by RT325 on topic What carb specs for 1977 DT250?
Not sure where this is or the currency. Pretty pictures if nothing else.
allegro.pl/oferta/gaznik-yamaha-dt-250-4...01-01-00-14647204686
Also a link here to Aliexpress which is where i wollow in cheap stuff with no real issuues [so far lol].
Last 28mm i bought still works ok on a 175.
But there's all sizes up there if you go looking.
www.aliexpress.com/w/wholesale-yamaha-ca...productlist.search.0
The following user(s) Liked this Post: mjf6866
Last edit: 31 May 2024 21:49 by RT325.
31 May 2024 20:25 #2
  • mjf6866
Replied by mjf6866 on topic What carb specs for 1977 DT250?
Thanks for the link!  To add to my confusion, I think I found that carb on Amazon but it doesn’t match up with the part number for the 77 DT250.  Im always hesitant to buy those Chinese carbs for these bikes…have you had good luck with any?
then there is someone on eBay that says it’s for a 77 DT250, but had a flat two bolt mount style that goes up against the cylinder instead of the two cylindrical openings on either end.
Last edit: 31 May 2024 21:18 by mjf6866.
31 May 2024 21:15 #3
Replied by OldBikes4OldMe on topic What carb specs for 1977 DT250?
I have a 77 DT250.
With the original owners manual.
Let me know if there is anything i can look up for you.
David
31 May 2024 21:39 #4
  • Ht1kid
  • Ht1kid's Avatar
Replied by Ht1kid on topic What carb specs for 1977 DT250?
Greetings from Tennessee USA.
31 May 2024 21:42 #5
Replied by Swoop56 on topic What carb specs for 1977 DT250?
This list is from an original Australasian Parts book , but should be pretty much the same as a US model .
Main Jet             # 150
Slide cutaway         1.5
Needle jet              N - 8
Needle                  5DP33-3
Pilot jet               #  50
Float Valve          # 2.8
Compare with what you currently have in your carb .
31 May 2024 22:13 #6
Yeah to be honest the one i put on my 175 yamy i had to adapt a mikuni main jet but cant remember now if it was too rich or lean as delivered. For $16 i didn't really care.
The one i bought for the Honda was perfect jetted out of the box.
Bought one for an LT50 kids quad which was ok straight off. Maybe i just had a lucky run.
31 May 2024 23:35 #7
Replied by ScottMalv on topic What carb specs for 1977 DT250?
yes,  the Mikuni VM 28 was also for the 250, that's good you had no issues with the AliExpress ones, but mjf, i would get one through ebay and or  HVC Cycle.
good luck,
Scott
06 Jul 2024 12:49 #8
