77 Dt 250 set timing on a bike that wont start.
Ok that's good, ya almost there. I can hear the ring ding noise. I'd go a little less than 16 but at least ya good to go now. Look forward to some good news next time.
Thanks for the honest update.
Please be sure the flywheel nut is Tight or it'll be a problem.
Need a solid hold.
I'll post a pic of mine which might be overdoing it but you'll get the idea. They make a mess of the shaft it things let go. Pic coming if i can find it.
Here tis photos.app.goo.gl/ZSNSV7ypGZ98s4UF9
Last edit: 29 May 2024 00:04 by RT325.
28 May 2024 23:56 #21
  • MrDrSirMan
  • MrDrSirMan's Avatar Topic Author
Replied by MrDrSirMan on topic 77 Dt 250 set timing on a bike that wont start.
Yeah I have it torqued to spec already. We have the same flywheel holder. works on sprockets too. Hell I even tightened it down as hard as I could and used it on the center part of a clutch in lieu of the correct tool.
29 May 2024 15:26 #22
  • Reed valve Richards
  • Platinum Member
  • Platinum Member
Replied by Reed valve Richards on topic 77 Dt 250 set timing on a bike that wont start.
@RT325 shees with that extension bar setup I'm surprised you didnt crack the nut!
Yo Joe, Go Joe
29 May 2024 17:33 #23
Original nut is a long one so not easily damaged.
Not sure if nuts come in different trensile strengths like bolts do, but if so i'd say originals must be of high tensile material.
www.partzilla.com/product/yamaha/90170-1...9900d514426b12aba0c5
Last edit: 29 May 2024 20:10 by RT325.
29 May 2024 20:08 #24
  • MrDrSirMan
I got it running far better than it was before boys. Thanks for all the suggestions.
Last edit: 04 Jun 2024 19:24 by MrDrSirMan.
04 Jun 2024 19:24 #25
Congrats!
04 Jun 2024 21:40 #26
