DT175mx 1978 - oil pump “piston” movement
- MikeK-uk
Replied by MikeK-uk on topic DT175mx 1978 - oil pump “piston” movement
Doh…
Yes ACW…. I turned it over with the kick start and replicated the ACW rotation.
No idea why I replied CW…. Senility setting in.
Mike
Mike
15 Jan 2024 12:22
#11
- MikeK-uk
Put some 2T oil down the bore and spun it over with battery drill with spark plug out and piston moved to & fro :-)
Thanks.
Mike
Thanks.
Mike
15 Jan 2024 12:32
#12
Replied by Gr8uncleal on topic DT175mx 1978 - oil pump “piston” movement
Good news.
Just double check that the flywheel bolt wasn't loosened during the procedure (don't ask why I'm asking!
15 Jan 2024 12:50
#13
- MikeK-uk
Ooooh…. Wouldn’t want that!
Will check and thanks for the tip.
Mike
Mike
16 Jan 2024 10:13
#14
- MikeK-uk
First start achieved :-)
Started on premix from auxiliary fuel tank and saw oil pump up to carb through my clear oil feed pipe.
Weep from transmission sump plug (nipped up), petrol p**sing out of carb over flow pipe (have a new yamaha needle valve to fit) and a single drip the counter shaft seal (will keep an eye on that).
Overall very pleased - it sounded sweet!
Thanks for your help to get this far.
Mike
Mike
The following user(s) Liked this Post: MarkT, Schu, Ht1kid, pahiker
22 Jan 2024 15:03
#15
Replied by MarkT on topic DT175mx 1978 - oil pump “piston” movement
Nice work! Congratulations!!!!
The following user(s) Liked this Post: MikeK-uk
22 Jan 2024 15:32
#16
