'78 DT400 Idle question
- RamadiRat
'78 DT400 Idle question was created by RamadiRat
This is a fully warmed bike, she starts on the 2nd crank pretty reliably, pulls great. Just not sure what this pulsing idle could point to, I am not certain I have the air/fuel/idle adjusted correctly...
Video: youtube.com/shorts/LM-qwlNhRcQ?feature=share
18 Nov 2023 15:09
Replied by RT325 on topic '78 DT400 Idle question
Thanks for the Vid.
To me it just sounds terribly lean.
Shortest answer i've ever given haha.
18 Nov 2023 16:41
- RamadiRat
Replied by RamadiRat on topic '78 DT400 Idle question
Might be the best answer ever! we'll see
18 Nov 2023 16:55
- Wrench66
- Content Contributor
Replied by Wrench66 on topic '78 DT400 Idle question
Classic lean idle drone sound..... richen up your idle mixture a 1/4 to 1/2 turn, IF it can't be richened enough before getting close to closing the air screw then richen the pilot jet one size (or two sometimes). You want that nice bubble sound
This video shows about what you want.
The later street two strokes (Dt's and the RD's) were leaned out a bit much for me..lol.
Good luck-- Ray
Good luck-- Ray
Nothing makes me smile like the smell of Blendzall green label
21 Nov 2023 11:25
Yep exactly as WRENCH66 says.
Not a 400 but same end result of a good mixture setting.
Yours being so lean at idle [& even higher up above a proper idle].
'i think' you'll need to go up in pilot jet size by quite a bit [or it's almost blocked--something to check first].
On listening to the original video again, it answers to throttle positively, so re-thinking that it's all pilot related.
Have you had the carb right apart, needle jet [emulsion tube] right out to inspect plus check airway to 'that tube' although a blocked airway would make it richer up towards & also when the needle taking over.
The pilot outlet hole to the venturi on the motor side is on an angle & the progression hole is straight up, but both fed by the pilot jet & could get blocked or restricted although unlikely.
Float level not so low the pilot can't find the fuel?.
If [in my opinion] the pilot jet is big enough & sounds about rich enough at 1.5 to 1.75 turns out then turning it right home should just about stall it from richness [if its idling slow enough in ther first place].
Replied by MarkT on topic '78 DT400 Idle question
With the idle speed so high, my thought is air leak.
21 Nov 2023 16:34
Trye that!!. edit Meant 'True that'!!--I go for hard stuff first lol then find its running out of gas.
