Re:1980 Yamaha DT175G correct compression
- Tolisano7@gmail.com
1980 Yamaha DT175G correct compression was created by Tolisano7@gmail.com
What is good compression for my 1980 DT175?
Sent from my iPhone using Tapatalk
13 Nov 2023 10:39
Replied by Tolisano7@gmail.com on topic Re:1980 Yamaha DT175G correct compression
I currently have 130.
13 Nov 2023 11:47
- Tinkicker
Replied by Tinkicker on topic Re:1980 Yamaha DT175G correct compression
I have zero.
13 Nov 2023 12:15
Replied by MarkT on topic Re:1980 Yamaha DT175G correct compression
130 is fine. Compression readings are a very unreliable indicator in these engines, different gauges and different technique can give vastly different results. Your bike has 130 with your gauge and technique... you can use that to compare with your future readings.
13 Nov 2023 12:37
Replied by RT325 on topic 1980 Yamaha DT175G correct compression
130 sounds good without researching it.
I just go by the bouncy feel on the kickstart.
You get a feel of it after years of doing it on any & every size motor.
How does your motor run.
Does it idle nice, & sort of lumpy as it fires through strong compression.
If very low it will struggle & hold a flat line idle while trying to fade out & stop--need the speed screw turned up [in] more than need be--not sound happy.
I'd say ya 'all good'. In saying 'that' i'm sure i remember DT175's at that time coming out with those rings made of something you could just about tie a knot in & flexed without breaking but didn't do a great sealing job that rings should do.
Sorry if that starts worry [correct me someone please if i'm wrong].
I worked for Yamaha locally in those years. [workshop].
13 Nov 2023 12:40
And just FYI, Yamaha never published any numbers for these bikes... probably because of what I just said... readings can vary widely on the same engine with different gauges and different people doing the test.
13 Nov 2023 12:44
Replied by Tolisano7@gmail.com on topic Re:Re:1980 Yamaha DT175G correct compression
Mark T and RT325
Thanks for input. Bike runs and idles strong now.
I had a blown out base gasket. The idle was all over the place.
So I repaired that and put a new Wiseco piston and rings. Bike runs really good and finally idles like it should.
13 Nov 2023 14:19
Cool, base gasket sure upsets carburation.
14 Nov 2023 13:23
