Oil Pump End Cap?
- Tinkicker
Replied by Tinkicker on topic Oil Pump End Cap?
Thanks Mark. I found one 21mm x 4mm in the UK. I will hold off on the welch dish plug and wait for this one to arrive.
I will report back if suitable.
Link.
www.bearing-king.co.uk/bearing/ec21x4-en...ide-x-4mm-wide/24791
Link.
07 Aug 2023 14:06
#11
- Tinkicker
I was wrong. The 21mm x 5mm shaft end cap is not close, it's exactly what Yamaha used.
Good detective work. Perhaps there should be a sticky where useful stuff like this can be kept.
07 Aug 2023 14:20
#12
Replied by RT325 on topic Oil Pump End Cap?
I guess there's no pressure involved as pressure is created in the plunger shaft thingy, if ya call it pressure to send the oil up to the cylinder.
07 Aug 2023 16:13
#13
Replied by Gr8uncleal on topic Oil Pump End Cap?
Weird, Yamaha listed the oil seal for when the priming wheel was fitted there, but not the blanking plug when it was removed on the later models.
Anyway, looks like you've got it sorted between you!
08 Aug 2023 00:21
#14
