77 Dt400 Carb
  • DaytonaBarnFind
  • DaytonaBarnFind's Avatar Topic Author
77 Dt400 Carb was created by DaytonaBarnFind
My 77 Dt400 carb is shot. If I buy a new VM34 from sudco the stock airbox won't fit, new carb is 58mm on airbox side, while the stock is approx 48mm. Will the stock throttle cable work? Has anyone done this? Thx in advance...
Sent from my SM-S911U using Tapatalk
03 Aug 2023 19:27 #1
  • 's Avatar
  • Visitor
  • Visitor
Replied by on topic 77 Dt400 Carb
If Sudco can supply the VM jetted for your application, its worth considering for sure.
It's not likely to be possible to obtain any current 34mm carb with a 48mm intake, so you will need a stepdown adapter to reduce the size of the intake, or fit a bigger air cleaner hose.
Without the settings for the VM, something like this will be far easier to set up, and very well priced:
www.aliexpress.com/item/1005005461510315...eLogUid=deKBwh7E6Y1s
03 Aug 2023 23:09 #2
Replied by MarkT on topic 77 Dt400 Carb
Cable won't work either without mods.  77 has a "tall slide cap"
What's wrong with your stock carb?  It's rare that they can't be fixed.
04 Aug 2023 05:34 #3
