81 DT125 compression & seals ?
- Jfrey45
81 DT125 compression & seals ? was created by Jfrey45
I have an 81 DT125 that I just started working on, the most compression I can get it 120psi after 5-6 kicks, throttle open. Is that where it should be?
Are the crank seals replaceable without splitting the cases, I know this bike has sat in a shed for about 15 years. The spark is a little week, I am thinking I need to clean all the electrical connections, and the grounds on the coil.
19 Jun 2023 09:27
Replied by MarkT on topic 81 DT125 compression & seals ?
Sounds fine to me.
Yes seals can be replaced without splitting cases
Make sure plug is gapped to spec, new out of box it likely won't be. (You have a CDI magneto, spark is not super bright and can be hard to see at all in bright light, normal.)
19 Jun 2023 12:14
- Jfrey45
Replied by Jfrey45 on topic 81 DT125 compression & seals ?
Thanks Mark, sounds like from your description my spark might be ok. I just finished going trough he carb, and the reeds look like they are closing tight, so getting new seals looks like the next step to getting it running. Then I can move on to restoration.
19 Jun 2023 14:11
Get seals from Yamaha... I use the 1977-79 IT175 crank seals... better ignition side seal.
19 Jun 2023 19:21
- Jfrey45
Seals are ordered, sorry this project docent get a lot of attention, maybe once I get running it will move alone faster.
I found some torque specs reprinted from a DT 250B/400B service manual, but it just shows bolt and nut sizes. Would they be the same on my DT 125? I haven't found one that tell the torque on each bolt like clutch basket act.
07 Jul 2023 13:02
Read the manuals. Torque specs are all in there. Manuals are in Tech Library.
07 Jul 2023 16:09
- otbmf
Replied by otbmf on topic 81 DT125 compression & seals ?
fwiw 120 psi is what I get on both my '78 DT 125's (5 - 10 kicks) - same motor as yours. Second MarkT's suggestion of IT seals. And ya, the spark is woeful, I have to close garage door and turn off lights to be sure it's there...
If you're not concerned with keeping it stock, and can throw a bit of dough at it (350 ish) I went with a 'vape ignition system', less maintenance and 12v...
11 Jul 2023 04:30
