DT175 1978 - oil pump pipes and unions
  • MikeK-uk
  • MikeK-uk's Avatar Topic Author
DT175 1978 - oil pump pipes and unions was created by MikeK-uk
Happy Easter all,
Doing a little more on my engine.
Almost ready to go for vapor blasting.
Another question along the way if I may…
Do the oil pump unions pull out? They seem very solidly in place!
That black pipe to the brass collar doesn’t want to come off either.
As always… thank you for your help.
Mike
PS I mean the engine case unions.
Last edit: 09 Apr 2023 17:33 by MikeK-uk. Reason: Clarification
09 Apr 2023 16:17 #1
Replied by Tinkicker on topic DT175 1978 - oil pump pipes and unions
Yes. They are tight, but are just a press fit in the case. As for the brass retaining collar, pull it off with a pair of snipe nosed pliers first, then the pipe should pull off the barbs.
The following user(s) Liked this Post: MikeK-uk, Jrkirkpa
10 Apr 2023 02:57 #2
  • MikeK-uk
Replied by MikeK-uk on topic DT175 1978 - oil pump pipes and unions
Thanks for that.
Put some heat on the case and put on my big boy pants… got it all apart.
Thanks,
Mike
10 Apr 2023 10:30 #3
