DT175H has spark, compression and plug is wet but wont fire
- msavitt
Replied by msavitt on topic DT175H has spark, compression and plug is wet but wont fire
can you put a finger over the spark plug hole when working the kickstart with other hand and see how hard it farts?
did you try a 2nd plug? I once had one that would spark on head but for some reason not under compression
09 Nov 2022 15:28
#21
- AirborneSilva
Replied by AirborneSilva on topic DT175H has spark, compression and plug is wet but wont fire
The good Lord didn't bless me with much reach but he did give me a low center of gravity
I did try another plug and ensured it was gaped properly. Thanks for the reply...
09 Nov 2022 15:31
#22
- Swoop56
Replied by Swoop56 on topic DT175H has spark, compression and plug is wet but wont fire
If you have an inductive timing light , you could check the timing marks line up ,
whilst spinning the motor over . might need an extra pair of hands though .
09 Nov 2022 16:17
#23
- AirborneSilva
I do have one, I'll see if I can manage it but that's if I can remember where it is, been years since I've used it.
Replied by RT325 on topic DT175H has spark, compression and plug is wet but wont fire
I guess RH crank seal has been mentioned but if popped out it'd be flooding the crnkcase with trans oil but wouldn't start either. Unlikely unless it got flooded with fuel while hibernating, then first kick pushed the seal out so no chance of starting after that.
See how the drill trick goes but mine being a 100cc in the video was easy to spin. I didn't see page 3 when i wrote this but think my answer probably still fits in.
- Tom P
Replied by Tom P on topic DT175H has spark, compression and plug is wet but wont fire
You don't have to kick it with your finger over the spark plug hole, you can stand on the right side and put your finger in the hole, then push the kickstarter with your left hand. Just make sure it's in neutral so it doesn't move forward in fall off the stand.
The following user(s) Liked this Post: AirborneSilva, Sneezles61
09 Nov 2022 17:40
#26
- Lizeec
Replied by Lizeec on topic DT175H has spark, compression and plug is wet but wont fire
Remove the spark plug and try a squirt of actual fresh pre-mix gasoline into the cylinder and reinstall the spark plug and try it again, I’ve found brake cleaner these days just don’t seem to have the explosive flammability of the old days, especially the non-chlorinated type they sell now days.
09 Nov 2022 21:35
#27
- AirborneSilva
Doesn't look like I'll be heading to Lowes today we're getting hammered pretty good right now from Nicole. I can at least try to check as Tom described.
10 Nov 2022 01:16
#28
- Sneezles61
Replied by Sneezles61 on topic DT175H has spark, compression and plug is wet but wont fire
Hang on Aiborne!
Sneezles61
Sneezles61
10 Nov 2022 05:11
#29
- AirborneSilva
Thanks Sneezels the worst is over, reported wind gusts in my town were max 69 MPH and just across the river from me is Cape Canaveral, they had wind gusts of 79 MP. Only one of my dogs wanted to go outside this morning, the other two just looked at me like - you gotta be sh****g me old man LOL
The following user(s) Liked this Post: Ht1kid, Sneezles61, Tom P
10 Nov 2022 05:39
#30
