78 DT250 only has 1st and neutral
Replied by RT325 on topic 78 DT250 only has 1st and neutral
My rat bike 360 lol.
The following user(s) Liked this Post: Snglsmkr, Sneezles61
07 Jun 2022 19:26
#11
- PDXtyist
- Content Contributor
Replied by PDXtyist on topic 78 DT250 only has 1st and neutral
Hi fellows. My TY250 has a very similar shift mechanism. I am having a problem shifting as well. I can’t seem to get the claw on shift lever 3 properly set équidistance from dowel pins in second gear. Any suggestions ? Engine was just rebuilt.
25 Jan 2023 08:14
#12
- AirborneSilva
Replied by AirborneSilva on topic 78 DT250 only has 1st and neutral
The following user(s) Liked this Post: PDXtyist
25 Jan 2023 09:03
#13
- Schu
Replied by Schu on topic 78 DT250 only has 1st and neutral
“Oh and one more stupid question what do I call this bike its completely stripped dt250 is it an enduro or a dirt bike or what would it be called”
I have several enduros that are stripped of all the street legal components. I simply refer to them as an Off-Road Conversion of a DT400B, or whatever model it was. You have to refer to it as a DT enduro to ensure that people know exactly what bike you are working on or questioning.
25 Jan 2023 09:20
#14
- YamahaForumUsername
Replied by YamahaForumUsername on topic 78 DT250 only has 1st and neutral
my bike's prefered pronoun is it/they
25 Jan 2023 10:39
#15
- PDXtyist
oh yes’ Dale has some amazing Utube explanations. It helps a bit, but I am still a bit uncertain about the TY250A’s (exactly like the DT250) shift adjustments. Especially:
-The left change lever (splined on shift shaft) and how it may need to be positioned on the splined shaft.
-The clawed shift lever being properly set equal distance from the drum’s dowel pins while in 2nd gear. I can’t see well enough to see if claw is in fact properly adjusted centered between the 2 dowel pins.
thank you fellows
thank you fellows
25 Jan 2023 18:47
#16
Replied by MarkT on topic 78 DT250 only has 1st and neutral
First question I have is are you riding the bike or trying to shift it on the bench?
Second question if are all detent balls and springs in place?
Usually if you don't screw with the adjustments... no reason to... everything works great on reassembly. I'm guessing that ship has sailed.
I think it was DEET that once wrote a great post on shift adjustment. Not sure if it was here or on the "other" forum that is now gone. You might try a search.
The following user(s) Liked this Post: PDXtyist, Ht1kid
25 Jan 2023 19:02
#17
- PDXtyist
Thank you MarkT.
Basically I m bench shifting as I am yet to get a chain installed. And yep, the detent mechanism is in place.
26 Jan 2023 10:54
#18
They don't shift well on the bench... to get it to shift much at all you need to be spinning the shafts so the dogs can align with the slots.
26 Jan 2023 13:38
#19
