Steering Damper
  • Mi73rt360
  • Mi73rt360's Avatar Topic Author
Steering Damper was created by Mi73rt360
OK so I am trying to refurbish the steering damper on my 73 rt3. Blasting the housing and replacing the o-rings. So I read where you use 30 wt. oil but I can not find as how to fill or how much to use. Do I fill one chamber or do I fill both chambers so if someone could fill me in on as what to do I would greatly appreciate it.
26 May 2018 10:45 #1
Replied by DEET on topic Steering Damper
I immerse them in a tub of oil with the two bleed screws removed.
Then I turn the wiper back and forth to remove the air.
Put the screws back in.
Remove from the oil bath and clean.
The following user(s) Liked this Post: RTD2, 1971DT250, AirborneSilva
Last edit: 26 May 2018 12:36 by DEET.
26 May 2018 12:35 #2
  • Mi73rt360
Replied by Mi73rt360 on topic Steering Damper
Al righty thanks for the info Deet.
26 May 2018 15:49 #3
