73 RT3 360 new owner questions
  • this_guy
  • this_guy's Avatar Topic Author
73 RT3 360 new owner questions was created by this_guy
Got a few questions:
(1) Fuel line and oil line sizes?
(2) Rebuild the VM30 carb or replace with a flat slide? Best source for the VM30 rebuild kit?
(3) Stock carb is a VM30, right?
30 Nov 2017 09:39 #1
Replied by Jogar on topic 73 RT3 360 new owner questions
Bump? For fuel line and oil line sizes ?
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
02 Sep 2021 21:44 #2
Replied by Gr8uncleal on topic 73 RT3 360 new owner questions
Parts list in the Tech Library on this forum indicates, for the fuel line, inner diameter of 7mm and length of 190mm.
02 Sep 2021 23:58 #3
Replied by shyted on topic 73 RT3 360 new owner questions
Hello This_guy , If you look on the task blocks on the pages you will see Tech library . If you open that and find your way to the related manual ,you can down load it for free as you're a site member.
I'm going to be putting a larger carb on mine and if you have a look through the threads by Turbo Dan on his DT 360,you'll see why. Flat slide carbs will fit with some inventing, Depends what you're trying to do. Is yours missing or rotted beyond repair or are you looking to get it to run better ?
03 Sep 2021 01:18 #4
Morning Dave.
Original post was from 2017!
I guess bumped by Jogar as no reply posted to original query.
03 Sep 2021 02:42 #5
Replied by Pete-RT1 on topic 73 RT3 360 new owner questions
"Morning Dave.
Original post was from 2017!"
Four years to get a reply, that's a response time nearly as bad as the DVLA
Yamaha CT3 (in bits)
03 Sep 2021 07:27 #6
