CT3 turn signals slow flashing
  • rsmith56
  • rsmith56's Avatar Topic Author
Replied by rsmith56 on topic CT3 turn signals slow flashing
I can live with it as is and it did pass state safety inspection. Just trying to get it up snuff. Everything else seems fine, with exception of the handlebar. It appears to be about 1/4 in out of true, looking at the crossbar in relation to the bar clamps.
I ordered the 6v-12v flasher off eBay that said for CT3.
15 Jun 2023 18:04 #11
Replied by Ht1kid on topic CT3 turn signals slow flashing
I wonder if you hooked up a 6 volt battery charger on low amps maybe 2 amp and see what it does when flashing
15 Jun 2023 18:31 #12
  • rsmith56
Good idea. I’lll give that a try. I’ll be back home and do so on Monday. Thanks.
15 Jun 2023 19:02 #13
Replied by SKYDANCER46 on topic CT3 turn signals slow flashing
Since your tail light or brake light doesn't dim even when your turn signals light up you can do what Ht1kid recommended and see if it gets them to flash or blink faster. I've done that many times testing the original Yamaha flashers. Or buy a 6v 2 prong electronic flasher sold now days. Most likely they will blink faster then.
Last edit: 15 Jun 2023 19:49 by SKYDANCER46.
15 Jun 2023 19:42 #14
  • rsmith56
I did hook a 6v battery charger at 2 amps with engine running, and no change. Went to 6 amps on charger, and no change. I’ll try the new flasher when it arrives.
thanks all
19 Jun 2023 09:20 #15
Replied by RT325 on topic CT3 turn signals slow flashing
Wouldn't need engine running to test blinkers with the charger connected. Just saying--!!.
19 Jun 2023 18:31 #16
  • rsmith56
I’ll try the charger only tomorrow. thanks
19 Jun 2023 19:08 #17
  • rsmith56
Hooked up th charger with bike not running. 2 amp, 4 amp, and 6 amp charging rates. None changed the lights.
Got the 6v / 12v two prong flasher in the mail. Hooked it up in place of the stock one. The lights flash quickly now. However I did notice with engine running in neutral that when left turn is flashing, turn indicator light and neutral light flashing alternately. Weird.
20 Jun 2023 10:42 #18
  • goatboy56
  • goatboy56's Avatar
Replied by goatboy56 on topic CT3 turn signals slow flashing
I also get "turn indicator light and neutral light flashing alternately" with an aftermarket 2 prong flasher so not sure if that is the cause or not.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
20 Jun 2023 11:15 #19
  • rsmith56
Oh well. The turn signals flash now. I can live with it , if it is doing no harm.
20 Jun 2023 11:27 #20
