How to install LH crank seal?
- Jbeebe
How to install LH crank seal? was created by Jbeebe
It seems i'm struggling every step of the way with this 73 MX250. I have a new crank seal, the one linked to here:
But for the life of me, it just won't go in evenly. I'm using a length of 2" capped pvc tube to drive it in but it just won't seat. After attempt #10 the seal is warped so I ordered another one.
I even put it in the chest freezer for a few hours beforehand.
I'm all out of tricks, is there something i'm missing??
22 Jul 2022 12:45
- msavitt
Replied by msavitt on topic How to install LH crank seal?
I've used my tusk crankshaft puller / installer to press the seal in, worked great if you have one
I have also used the PVC pipe with a PVC threaded pipe adaptor which has a nice shoulder, this worked too.
22 Jul 2022 17:03
Replied by RT325 on topic How to install LH crank seal?
If you grease or oil the seal & the case it should go in without too much resistance. If you use a good solid flat steel plate with hole & a steel tube to drive it, then if it starts to go crooked just concentrate the pushing over that side to straighten it. Sounds easy--in theory--but not always the case.
22 Jul 2022 17:17
- Jbeebe
Replied by Jbeebe on topic How to install LH crank seal?
What is everyone's vote on whether to put a light coat of black RTV or yamabond on the outer surface of the new seal? The metal mating surface has some slight imperfections and some irregularities that I can feel with my finger so I just want to be sure we're air tight.
28 Jul 2022 02:56
- Brzn
Replied by Brzn on topic How to install LH crank seal?
Just replaced the left side crank seal on my DT2 last Sunday;
www.yamaha-enduros.com/index.php/forums/...-dt2?start=60#151628
I applied a generous amount of 2 stroke oil to the inner circumference of the seal after thoroughly cleaning the crank and seal seat. I installed the seal with the outer surface dry (no RTV or Yamabond), pushing it in as far as I could with my thumbs, getting it as square to the case as I could tell. I then slowly tapped it in using a small block of wood and a hammer working my way around the seal a little at a time. I was working it on the outside edge of the seal until it was just flush with the case.
- Jbeebe
Alright got her seated with the following method:
1) Put seal in chest freezer (0 deg F) for a couple days
2) applied thin black rtv to outer mating surface of seal (very thin, only because of the imperfections in the case)
3) pushed in square as far as I could with hands
4) put metal plate with hole over crank
5) tapped in with 2" steel conduit and 3lb mini sledge hammer
The following user(s) Liked this Post: type one, RT325, JayB, Snglsmkr, Sneezles61, Brzn
28 Jul 2022 04:29
- Swoop56
Replied by Swoop56 on topic How to install LH crank seal?
I'm of the opinion applying the RTV is a mistake .
When I was young ( and dumb ) , I rebuilt my RD 350 engine , and RTV'd the seals outers .
During a race the countershaft seal popped out , lubing my chain and then tyre , until I discovered
" where the rubber left the road " .
On an RD the crankshaft seals have retaining lips , possible with horozontally split cases , so they wouldn't pop out ,
but in your case , you have provided a medium to allow the seal to do exactly that .
The following user(s) Liked this Post: MarkT, RT325, Lizeec, Pedalcrazy
28 Jul 2022 14:41
- DT400FRANK
Replied by DT400FRANK on topic How to install LH crank seal?
It's not backwards is it?
28 Jul 2022 20:31
- Brzn
Yours appears to be in opposite of how I installed mine.
29 Jul 2022 02:17
- Jbeebe
The plot thickens...
Here in the parts diagram it appears that I installed it correctly:
Anyone else want to help solve this?
29 Jul 2022 03:16
