RT2 Rear Brake Position/Height
  • Jammyyammy
  • Jammyyammy's Avatar Topic Author
RT2 Rear Brake Position/Height was created by Jammyyammy
Can you reposition the lever on the splined shaft? Or have I misunderstood the question?
04 Jun 2022 09:35 #1
Replied by MarkT on topic RT2 Rear Brake Position/Height
I've seen them bent upwards...  yours looks pretty good though.  I don't think there's a factory adjustable stop but I suppose you could build up lever or peg to lower to suit you or make something adjustable.
Another thought is to adjust your other bikes to match the pedal height on this one and it will likely stop being a problem after a little getting used to.  That's what I've found works for me.  And a little higher like the stock RT2 helps avoid accidentally braking...  especially on rough trails.
04 Jun 2022 10:35 #2
  • Jammyyammy
Replied by Jammyyammy on topic RT2 Rear Brake Position/Height
Or you could use a vice, some heat and a large hammer…
04 Jun 2022 13:42 #3
