Dt3 piston feedback
  • principal282
  • principal282's Avatar Topic Author
Dt3 piston feedback was created by principal282
A. The needle bearing basically disintegrated on removal.
b. Jug was a bugger but came off with patience,  and a shitton of soaking with a rust removal.
c. Look at the rings. This looks bad.
22 Sep 2021 15:27 #1
Replied by msavitt on topic Dt3 piston feedback
Do you have a photo of piston skirt?
23 Sep 2021 08:12 #2
Replied by shyted on topic Dt3 piston feedback
Are you on about the shape of the top ring or what looks to be pitting ?
Do you know that they have keystone rings ?
If you notice , the top ring land is stepped
The following user(s) Liked this Post: principal282
Last edit: 23 Sep 2021 15:47 by shyted.
23 Sep 2021 15:46 #3
  • principal282
Replied by principal282 on topic Dt3 piston feedback
I'll go snap a pic after supper. Original rings.  Dad did nothing but enjoy it til it didn't start the best anymore. Then he bought a different bike
23 Sep 2021 17:23 #4
  • principal282
Here is the sleeve
23 Sep 2021 18:05 #5
  • principal282
Hints of carbon.  No real pitting.
Piston measures 69.72
Jug 69.80
23 Sep 2021 18:15 #6
  • principal282
And .006 or 0.15mm side clearance
23 Sep 2021 18:18 #7
Replied by MarkT on topic Dt3 piston feedback
It's a standard piston still.  Nothing looks inherently "bad".
Except maybe your measurements...  it's not easy at all to measure accurately even if you have a large micrometer and a dial bore gauge.
You really need to take the parts to an experienced machine shop with the correct tools and two stroke experience to measure the bore and piston.    The bore would have been just a hair over 70 mm when new...  Probably like 70.005 mm  Piston would have been 69.972 mm by the markings.
Piston would wear smaller but bore would wear bigger.
Easiest "home brew" way to measure is a feeler gauge up from the bottom in the center of the skirt...  It's not accurate, actual clearance measured by the book will be larger...  If you got a 0.006" feeler gauge in there your actual clearance would probably be 0.008" or 0.009".  Might run but would rattle like hell and might crack the piston.
23 Sep 2021 19:08 #8
Trivia:  Sometimes on an original engine like your there will be a faint ink stamp on the outside of the sleeve where it slides into the case...  normally would say something like "005".  That would mean your bore was originally 70.005 mm.
The following user(s) Liked this Post: shyted, principal282, Sneezles61
23 Sep 2021 19:15 #9
  • principal282
I live near the edge of the earth. Its a 100 miles to a town where this sort of thing may be done, it's possible it's more local but...I've searched and cannot find any such place even close by.... but I will keep looking!
Last edit: 23 Sep 2021 19:28 by principal282.
23 Sep 2021 19:28 #10
