CT3-primary drive seal plate
  • ksours
  • ksours's Avatar Topic Author
CT3-primary drive seal plate was created by ksours
Reassembly and there is a plate missing that i found on a youtube video. It is on the right crank cover just below the tach gear and primary drive gear. It fits just under the primary drive gear on top of the seal.  I do not have this plate and can not find it on my parts diagrams. I believe it assures the seal from moving outwards. Does anybody have a part number for this plate? How necessary is it?
18 Sep 2021 08:32 #1
Replied by MarkT on topic CT3-primary drive seal plate
It holds the seal in...  pretty well anyway.  Early CT models didn't have it but it came on the later ones and Yamaha had a "retrofit" for the ones that didn't come with it...  CT3 should have had it from the factory if memory is correct.
See if you can find it in this diagram  www.partzilla.com/catalog/yamaha/motorcy...3/crankcase-cylinder
(Hint:  #25)
Last edit: 18 Sep 2021 08:48 by MarkT.
18 Sep 2021 08:47 #2
  • ksours
Replied by ksours on topic CT3-primary drive seal plate
Once again good job mark. I found it on ebay and they show 2 different versions. I found the right one with your part number. I don't want to keep replacing the seal so this was very necessary. Thanks again
18 Sep 2021 08:53 #3
Yamaha stills sells it so don't overpay on ebay.
18 Sep 2021 08:55 #4
Replied by Ht1kid on topic CT3-primary drive seal plate
 Yes holds the seal in
18 Sep 2021 08:55 #5
  • ksours
The use of the term "Hint" is pretty nice actually, I would be more prone to "A Slap on the back of the head".Hahaha
18 Sep 2021 09:00 #6
Wrong side sorry!!! Not enough coffee yet
18 Sep 2021 09:02 #7
  • ksours
I am glad you missed your coffee. I pulled the magneto and there was not one on that side either. Dumb luck for me I guess. Thanks a bunch guys.
18 Sep 2021 09:13 #8
You don't need one on the ignition side!
Stator plate does the job except on the early models.
18 Sep 2021 09:18 #9
Here's the bulletin...  It could be the CT3 didn't come with it.  I think the ignition side one was always dealer installed?  Not sure.
18 Sep 2021 09:28 #10
