Yamaha DT3 rear exhaust mount
- steam_biker
Yamaha DT3 rear exhaust mount was created by steam_biker
Does anyone make a replica rear exhaust mount?
It is an obsolete part, and mine is past it's best.
I can't be the only one with this problem.
Yamaha DT3 1973
Yamaha FZR 1000 Genesis 1987
Suzuki GS500e 1989
Yamaha FZR 600 Genesis 1991
Yamaha YZF 750R 1993 Yamaha FJ 1200 1990
Yamaha FZR600R 1994
Suzuki GS500e 1989
Yamaha FZR600R 1994
11 Sep 2021 08:03
Replied by Gr8uncleal on topic Yamaha DT3 rear exhaust mount
I would imagine any short length of metal can be used and a grommet or such like fitted at the exhaust end to give a degree of rubber mounting.
Even if you did find a new one now, there's no guarantee that the rubber on it won't have deteriorated.
The following user(s) Liked this Post: steam_biker
11 Sep 2021 08:09
- Pedalcrazy
Replied by Pedalcrazy on topic Yamaha DT3 rear exhaust mount
If that is the two pieces of metal with a rubber block between them like my RT3 and it’s all there but separated…I sand blasted the parts to get them good and clean then used super glue and a strong clamp to put them back together. A couple coats of flat black and looks and works like new. Been a few months and working great. Gotta get the surfaces spotless so the glue bonds at it’s best. Otherwise look on eBay…I got an NOS one as a spare but haven’t needed it.
11 Sep 2021 08:12
- steam_biker
Replied by steam_biker on topic Yamaha DT3 rear exhaust mount
Yes, it is the part that you're talking about. As far as I know, the RT3, uses the same part. I will try to repair it. I just thought that someone would have made a reproduction part, there have been many parts reproduced.
Yamaha DT3 1973
Suzuki GS500e 1989
Yamaha FZR600R 1994
Suzuki GS500e 1989
Yamaha FZR600R 1994
11 Sep 2021 08:19
- 1971DT250
Replied by 1971DT250 on topic Yamaha DT3 rear exhaust mount
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=334138425149&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by MarkT on topic Yamaha DT3 rear exhaust mount
Modern YZ85 (all the way to 2021 model) uses a similar part to mount pipe ... I think it's shorter... but I've adapted to other applications without much fabrication. Can be bought at any Yamaha dealer for $20 to $25 and fits many bikes perfectly (like my DT50's).
www.partzilla.com/product/yamaha/565-14771-00-00
The following user(s) Liked this Post: steam_biker, Gibz
11 Sep 2021 08:24
Wow... Nice find 1971DT250!!!
11 Sep 2021 08:27
+1
+1
11 Sep 2021 08:45
- Sneezles61
Replied by Sneezles61 on topic Yamaha DT3 rear exhaust mount
I tried epoxy... fell apart... So I drilled a hole put a bolt with a nut that has the nylon insert... I only tightened enough to keep them together... It can still wiggle a bit if it needs too..
Sneezles61
Sneezles61
The following user(s) Liked this Post: gvthnks, steam_biker
11 Sep 2021 14:02
- hcdiiiga
Replied by hcdiiiga on topic Yamaha DT3 rear exhaust mount
+2. I've been staring at an OEM for $145.00 for some time on Ebay.
12 Sep 2021 03:01
