Two oil lines running from Autolube tank
  • bobmitchum
  • bobmitchum's Avatar Topic Author
Two oil lines running from Autolube tank was created by bobmitchum
I pulled off my 72 RT2 Autolube tank to repaint the "360" and clean it up - and damned if now I can't
recall which of the loose hoses goes back onto each of the upper and lower outlets on the Autolube tank.
I know this is real basic, and I'm embarrassed to ask because it should be self evident - but if anyone has
a photo or diagram of the two hoses, and perhaps their origination point on the engine block/casing going to the
autolube tank ---- I'd sure appreciate the assistance. And will photo it all next time, prior to tearing it apart !
Grateful for any assistance, here.
04 Aug 2021 12:32 #1
Replied by run103 on topic Two oil lines running from Autolube tank
The line out of the bottom of the tank goes to the oil pump  the other line is the breather tube  goes over and ties to the frame and would dump oil onto the chain if it overflowed Doug
04 Aug 2021 15:49 #2
  • bobmitchum
Replied by bobmitchum on topic Two oil lines running from Autolube tank
Oh man - thank you so much ….
Sincerely appreciate this.
04 Aug 2021 16:13 #3
