no spark after sanding the points.
  • Bdee
  • Bdee's Avatar Topic Author
What kind of damage can a novice do while attempting to clean the points with 800 grit sand paper and then spraying everything in the vicinity with contact cleaner?    CT3, if it matters.
During the same session I removed the tank, installed new tank cap innards and a new petcock. Could I have inadvertently damaged a wire or connection ham-fisting the tank re-installation.
the only thing I have tried is a new spark plug and re-seating all the connections that live under the tank.
Did not have any spark problems before this.
06 Jul 2021 20:33 #1
Replied by MarkT on topic no spark after sanding the points.
Point contacts are probably not clean.  Cut strips of white uncoated business card and pull them through the points until paper comes out clean.
The following user(s) Liked this Post: Bdee
06 Jul 2021 21:23 #2
  • Bdee
Replied by Bdee on topic no spark after sanding the points.
Thanks Mark. I will do so. I have a gazillion of unused business cards.
06 Jul 2021 21:34 #3
Replied by RT325 on topic no spark after sanding the points.
Only takes a spec of sandpaper grit left behind to 'not' work. Have you dislodged the wire to the coil under the tank when removing or re-fitting.
07 Jul 2021 01:42 #4
