1972 Dt2 250 ignition switch
  • wbrewstersr@gmail.com
  • wbrewstersr@gmail.com's Avatar Topic Author
1972 Dt2 250 ignition switch was created by wbrewstersr@gmail.com
Can anyone tell me where I can buy a compatible ignition switch for my 1972 DT 2 250
I picked up a cheap 4 wire switch but I don’t think it will work
for my bike
Any help is appreciated
thanks
26 May 2021 23:42 #1
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 1972 Dt2 250 ignition switch
I picked up a very slightly damaged one cheap off fleabay (I'm in the UK) - it was still fitted to the mounting bracket, but the clocks were mangled .
First up, research exactly what the part looks like and then do a very broad search on ebay (eg DT clock, DT clocks, RT clock, DT switch etc etc). A lot of sellers don't have detailed knowledge of what they're selling and the part you want might have been retro fitted, in error, to a different model.
Be prepared to have to buy a new key - the number is on top of the barrel. If this part of the switch is missing (it was on mine), you will need an old school master locksmith to cut a key for you. Saying that, it's likely that the barrels can be swapped (I don't have the skill for that!).
Also be prepared to replace the silver/grey protective sheath over the wires - DEET here sells great new stuff.
I'm not sure, but I think that wires from the CT2/3 switch might be the same colour, but the end connections and wire length might be different - others will have to comment on this.
27 May 2021 01:13 #2
Replied by wbrewstersr@gmail.com on topic 1972 Dt2 250 ignition switch
I found an ignition on eBay it looks like the one I need pus it comes with a speedometer which I also need
here is a pic of it
27 May 2021 08:38 #3
  • Gr8uncleal
That looks like one for a CT2/3. However, if you change the connections on the 4 pin block it might still be fine. Speedo is the same, I think.
I'll post photos and dimensions of mine after tea (teatime here in the UK!). You'll also need to compare the wiring legends for the DT2/3 and CT2/3.
27 May 2021 08:53 #4
  • Gr8uncleal
Here we go.
One 6 pin block connector and 4 singles - 2 male ( red, black) and 2 female (white, blue).
The approximate length of the wires, from the base of the switch to the ends of the connectors, is 17 inches.
27 May 2021 09:54 #5
  Thanks I am sure I will have more questions about the wiring
thanks for your help
The following user(s) Liked this Post: Rick C., MarkT
27 May 2021 11:09 #6
