bad starting when hot.
- Aubs
bad starting when hot. was created by Aubs
Hi , I have an ex USA 1973 DT250 Starts easy when cold and runs well . However when after a good run engine is stopped and tried to restart will not fire up on kickstart. New plug ,points and condenser recently fitted. Using ethanol free fuel with 50-1 ratio. Hope someone can help. Possibly not related but fuel filter bowl is never full but I never seem to suffer from fuel starvation.. Aubs from Wales.
02 May 2021 06:12
- Xtgeezer
Replied by Xtgeezer on topic bad starting when hot.
Hi there I have the same bike with the same issue do you have any answers on this issue please?
02 May 2021 11:17
- JayB
Replied by JayB on topic bad starting when hot.
Could be that it is on the rich side when hot. Don't use the choke when starting hot. Try holding the throttle 1/2 to fully open when starting hot. If you pull the carb make sure the float setting and needle clip position are correct.
The following user(s) Liked this Post: Xtgeezer
Replied by MarkT on topic bad starting when hot.
Do you have the insulator spacer between carb and engine?
How much time is passing before trying to restart?
03 May 2021 07:22
- Hammer
Replied by Hammer on topic bad starting when hot.
Aubs,
The 1973 was, in the US at least, the DT-3, and not a DT250; this could help when looking for rare replacement parts.
On starting, when cold, use the Choke, and DON'T TOUCH THE THROTTLE! When warm, use no choke and about one-third of throttle travel and kick when the piston is at TDC.
Hammer
Hammer
03 May 2021 21:09
- Aubs
Replied by Aubs on topic bad starting when hot.
Hi MARKT I assume you are refering to the valve plate . Has been removed and checked. Time to restart after long run about 1 hour.
04 May 2021 01:07
I'm talking about the insulator spacer between carb and engine. Yamaha calls it an "intake manifold".
Should be an o-ring on end of carb, insulator, then gasket, then reed manifold.
Without an insulator, carb will soak up excessive engine heat which can make it hard to start when hot.
The following user(s) Liked this Post: swm, Schu
04 May 2021 07:25
- Aubs
Hi MARKT, THANKS FOR THE REPLY. i WAS NOT AWARE OF THE PURPOSE OF SPACER. . i DO HAVE SPACER AND "O" RING IS IN GOOD ORDER.
05 May 2021 01:01
