1973 CT3 Cleaning transmission parts (removed from engine)
- Hercules Amadeus Amóre
1973 CT3 Cleaning transmission parts (removed from engine) was created by Hercules Amadeus Amóre
Can anyone suggest a solution in which to clean my gears, forks and drum? There was an incident that caused some metal shavings to be in my engine for a while and I'd like to be sure they're all cleaned before put the engine back together. What's everyone think? Dish soap? Kerosene? Mineral spirits? Something else?? See below for a pic of the gears and thanks!
14 Apr 2021 14:58
Replied by RT325 on topic 1973 CT3 Cleaning transmission parts (removed from engine)
I guess Kero then wash it off with garden hose & oil it up. I just used to use petrol in the old days. If you cant see the shavings then they can't be there. It'll be good.
14 Apr 2021 15:37
- Rick C.
Replied by Rick C. on topic 1973 CT3 Cleaning transmission parts (removed from engine)
Brake clean. or Kleen as they call it
- msavitt
Replied by msavitt on topic 1973 CT3 Cleaning transmission parts (removed from engine)
I am a huge fan of BBQ lighter fluid, Walmart is 40% cheaper than anywhere else
14 Apr 2021 19:36
Gosh that sounds pretty volatile. mind you i'm thinking of totally bathing it in the stuff, kerosene whatever, like about 10 litres of it & roll the shafts around.
14 Apr 2021 19:46
- DT Tim
Replied by DT Tim on topic 1973 CT3 Cleaning transmission parts (removed from engine)
Definitely kerosene, years ago we would have it in the parts cleaner until more modern, environmentally better fluids came but they never cleaned as good. Then let dry a while then use an air line to blow dry and clean , followed by oiling.
I recently purchased a new engine case oil plug that's magnetic, properly a good idea too.
14 Apr 2021 23:06
- alnarv
Replied by alnarv on topic 1973 CT3 Cleaning transmission parts (removed from engine)
I use mineral spirits, (it is low volatility, relatively cheap, and does a good job of disolving oil & grease) then blow dry and follow up with detergent/hot water and another blow dry.
alnarv
alnarv
15 Apr 2021 05:39
- mdscott
Replied by mdscott on topic 1973 CT3 Cleaning transmission parts (removed from engine)
Autozone degreaser, then blow dry. It's cheap, I keep a supply.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
