My first 2 stroke.
  • Yamrt3
  • Yamrt3's Avatar Topic Author
My first 2 stroke. was created by Yamrt3
I have an RT3 and just took off the carb and pulled it apart to clean it all. I need a new gasket that goes between the float bowl and the carb body. They are still available thru my local yamaha dealer but it is $30.00. Can I use something else or is it best to pay the money and get this gasket?
09 Apr 2021 11:18 #1
Replied by msavitt on topic My first 2 stroke.
suggestion would be to get part no. from Partzilla and check out eBay
often times Partzilla is way cheaper than eBay sometimes the other way around
I have also scored certain parts on Amazon, but way less frequently
congrats on 2 stroke
09 Apr 2021 12:02 #2
  • Yamrt3
Replied by Yamrt3 on topic My first 2 stroke.
Thanks, iI'll check Partzilla right now. I just took my carb parts out of my ultra sonic cleaner and am ready to reassemble. they look great. I'll go find the gaskets and o rings i need now. Maybe I should just buy a rebuild kit instead of a couple of gaskets and o rings. Your thoughts.
09 Apr 2021 12:36 #3
i learned the hard way to make sure all jets are the correct size as much can change in 30 to 50 yrs and to only use jets that have the microscopic Mikuni logo which i can only see with backwards binoculars!  you can probably look stuff up on this website
good luck getting it started
09 Apr 2021 14:10 #4
Replied by Swoop56 on topic My first 2 stroke.
Aftermarket Carb kits are fine for sourcing float bowl gaskets , and
float valves . However resist using the other brassware as they usually
don't equate to the OEM Mikuni parts closely . Better to go Genuine Mikuni
or OEM Yamaha parts for those .
09 Apr 2021 14:41 #5
  • Yamrt3
Great info, I did not know all that. will do. Thanks.
09 Apr 2021 15:16 #6
  • Yamrt3
More stuff I didn't know,. thanks for the heads up. Taking a lot of notes. Dan.
09 Apr 2021 15:17 #7
