DT400C Wiring Diagram
- Superdad60
DT400C Wiring Diagram was created by Superdad60
Hey allMaking a color diagram for my garage for my DT400Helps my old eyes follow betterSome of my old wires I have yet to uncover near the CDIany one help me identify the rest so I can finish this up and share?Also what actual color is Ch wire on the Left Turn? (Chartreuse?)Also I have a 400C and this says 400B and shows what looks like 3 coils and I only have 2
Replied by Gr8uncleal on topic DT400C Wiring Diagram
Left turn Ch = Chocolate, often just referred to as Dark Brown.
The following user(s) Liked this Post: MarkT, Superdad60
08 Apr 2021 07:06
Replied by MarkT on topic DT400C Wiring Diagram
You guys are very skilled. Above is the correction for that diagram.
If you have a C model, might be better to start with that diagram... there are slight differences like a voltage regulator.
There is a DT400C OWNERS manual in the Tech library. Diagram is in the back. Wires are labeled with color legends.
If you're talking about the stator coils, the four main coils are wrapped around two common cores... coils are drawn next to each other in diagram to clearly show how the wires interconnect but there are only two cores.
P.S. Ch = Dark Brown
The following user(s) Liked this Post: Superdad60
08 Apr 2021 07:19
- Superdad60
Replied by Superdad60 on topic DT400C Wiring Diagram
Got the 1975 400B manuals and thanks
Should have gotten these first as they are fantastic
I take it for my 1976 400C there are minimal changes and I can just go by this manual since I did not see one for my year (other than a V regulator)
I think I still have a rectifier?
Thanks for the coil clarification
Again, there is an OWNERS MANUAL in the tech library that has the correct diagram for you bike.
Here's a link that hopefully works. yamaha-enduros.com/index.php/ownders-man...t400c-owner-s-manual
And yes you have a rectifier.
08 Apr 2021 09:34
