Fender repair
- Burrage
Fender repair was created by Burrage
Any top tips on how to repair this fender? Patch? Filler? Or replace? Any help and wisdom welcome!!!
03 Mar 2021 11:59
- 1971DT250
Replied by 1971DT250 on topic Fender repair
I suggest replacing it.
The following user(s) Liked this Post: Yamadude
03 Mar 2021 12:42
- Mothersbaugh
Replied by Mothersbaugh on topic Fender repair
If it's for a CT-2, I have you covered for $25 and postage.
03 Mar 2021 15:01
- Yamadude
Replied by Yamadude on topic Fender repair
Any piece of metal bodywork can be repaired (see You Tube for how-to's) but you are faced with a cost/labor/materials/replacement balance analysis. Sometimes a quick replacement can be the ticket. You've been offerred a good deal (above).
You can just call me Dude.
Syracuse, New York
Syracuse, New York
03 Mar 2021 15:58
- Burrage
Replied by Burrage on topic Fender repair
Hi - thanks! It for a 1973 DT3 250 - I will need to check compatability - but as I am in the UK... I suspect shipping will cost me a small fortune, let me check and I'll come back. Cheers!
04 Mar 2021 00:12
- Enduro nut
Replied by Enduro nut on topic Fender repair
For situations like that i have my brothers fix it. They are proffestional welders so what i would do if i was in your shoes is find a piece of steel thats approximently the same thickness, cut it down so it just fits inside the hole then have it welded in. Once welded in then we would grind it and probably have to add a little weld and grind some more until we get it so it looks and feels as if it was never there. We have done stuff like this in the past and it always amazes me how skill full they are with a welder and grinder.
04 Mar 2021 04:03
- Mothersbaugh
So you'd call them virtuosi with the welders and grinders?
04 Mar 2021 06:27
