1973 DT3 Restoration : Testing the Ignition Coil
Replied by RT325 on topic 1973 DT3 Restoration : Testing the Ignition Coil
The following user(s) Liked this Post: 1971DT250, Swoop56, Yamadude
02 Mar 2021 00:10
#11
- yamahahaha
Replied by yamahahaha on topic 1973 DT3 Restoration : Testing the Ignition Coil
I think I saw one of those from an old " Lost in Space" episode
The following user(s) Liked this Post: RT325, Yamadude, TresCuatros
02 Mar 2021 01:21
#12
- Yamadude
Replied by Yamadude on topic 1973 DT3 Restoration : Testing the Ignition Coil
RT, Thanks for your replies. I'm going to respond to you and Mark separatly, since you both brought up a number of items.
I'm looking forward to winter ending soon here in Syracuse NY cuz I have plans to make a video to document the performance issue I had last year. I'm not going to try to describe it cuz my memory of it has faded a bit (old age). Look for another posting from me in a few weeks.
I can say that I have covered the carb, the oring thoroughly. And the exhaust.
The coil testing you did at work sounds interesting, but I don't have access to such a tester.
I like the cool Yamaha tester you pictured; I've only seen that once before, maybe it was yours.
I'm going to jump over to replying to MarkT and wrap up my current thoughts....
You can just call me Dude.
Syracuse, New York
Syracuse, New York
02 Mar 2021 06:12
#13
- Yamadude
Mark,
Thanks for your reply. No, you're not confused: I did in fact mention the 7mm gap test, which I read in the Clymer book, but the OEM manual was vague on what the test entails, so I edited that remark out of my post.
But I did do the test according to Clymer, simply pulling the high tension lead off the plug and holding it 7mm from the cylinder head, and kicking. It did bridge the gap with a blue-white spark which was moderatly bright.
When I check the spark at the spark plug (kicking) held against the cylinder, the spark is bright at first, but becomes a bit less intense as I kick and kick, and it gets a bit irratic in intensity I have checked the points condition and gap.
With my other vintage bikes I have always simply replaced the condensers at the beginning, since they sometimes degrade over time, and they are inexpensive. So, I ordered a condenser and a flywheel puller for this bike yesterday.
I am inclined to replace this DT3 coil for the same reason (they sometimes bench test OK, but underperform on the road) like I have routinely done on my other bikes but Yamaha doesn't make them, and I'm disinclined to spend a bunch of money unnecessarily. This EMGO universal coil www.amazon.com/Emgo-Universal-Ignition-Coil/dp/B002EC389W was recommended by Makotosun back in 2016, currently an inexpensive $18 plus shipping. However, I'm wary of "Universal" parts, and no resistance values are offerred.
What do you think of the EMGO coil?
BTW, as I mentioned to RT, I'm planning on doing another thread when winter breaks here in Syracuse. I'll describe the performance issue and post a video.
Syracuse, New York
Syracuse, New York
Replied by MarkT on topic 1973 DT3 Restoration : Testing the Ignition Coil
I've probably posted this dozens of times: yamaha-enduros.com/index.php/forums/74-7...ignition-coil#120526
I've had good luck with the Emgo, others have too... looks like the one you posted. If I had to buy a new coil other than original I would go with the Emgo.
On "meter readings"... unless a coil has a open circuit or a short, I don't worry about the specs too much. The ET magneto Yamaha used is pretty robust and tends to work well with different ignition coils. Why I'm saying that is if you expect the Emgo to match the OEM specs, you're likely to be disappointed. I have a new spare Emgo I keep handy "just in case" and if you want me to measure the specs I can do it this afternoon.
The following user(s) Liked this Post: Yamadude
02 Mar 2021 07:30
#15
- Yamadude
Thanks Mark
I looked up the EMGO coil you mentioned in that thread you gave me. Here it is: www.amazon.com/Emgo-24-71532-Ignition-Coil/dp/B00230959C
Looks just like the one I mentioned, just a different color.
Yes, I'm curious about the resistance readings (even if they are not esssentially important), so if you had a minute to test your new EMGO that would be appreciated. And if you would check which EMGO item number it is.
EDIT: I just found that Dennis Kirk indicates " 1.0 ohm " for the EMGO 2471532
www.denniskirk.com/emgo/universal-igniti...01280.prd/201280.sku
Syracuse, New York
Syracuse, New York
- 1971DT250
Replied by 1971DT250 on topic 1973 DT3 Restoration : Testing the Ignition Coil
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=114535072691&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Hey they're everywhere haha--re-badged it seems. Good units too, not that i ever put it through all its capabilities.
02 Mar 2021 16:25
#18
"Yamadude", if you 'do' have a spark problem it'd be misfiring & running ratty all over & likely not want to start easily. General lack of power i'd be thinking something else maybe obscure but not spark--just saying, that's all. I'll go back n read the start of all this.
Ok, you say you've covered the exhaust, can you explain that a little more please. Sorry to be a pest.
The following user(s) Liked this Post: MarkT, Yamadude
- Yamadude
Hey,
I'm known as "Dude", not "The Dude", just Dude.
Or Jeff.
I don't mind your persistence at all, in fact it is appreciated. However, as I said earlier, the symptoms are vague in my memory cuz its been many months since I ran it, and I have 7 running bikes I'm attending to. And its winter here in NY , so I can't test it; the DT3 is indoors in my warm winter workroom. So, I'm preparing to post a detailed symptom update when I can get it outdoors, and I'll post a video of it running. Stay tuned!! But I can say that it starts well and idles well. My recent carb rebuild might have improved or cured the problem, fingers crossed.
But we can talk about the exhaust. I checked my records; it was actually my TY250 exhaust that I burned out last year, not this DT3. But I did just bead blast and paint it, so Im disinclined to burn it out. Is there some way to test it for air flow density? I can't think of a method. I think that automotive catalytic converter restrictions are tested using some sort of insertion of a MAF sensor before and aft of the CC.
BTW, I installed a new baffle at the rear as it had none and was very loud.
Or Jeff.
Syracuse, New York
Syracuse, New York
02 Mar 2021 17:21
#20
