DT3 (also DT2) Carb rebuild: Clogged Air Passageway? VM26SH
- Yamadude
DT3 (also DT2) Carb rebuild: Clogged Air Passageway? VM26SH was created by Yamadude
Hey guys,I'm restoring a 1973 DT3 with the original Mikuni VM26SH (which is also found on the DT2) which I am rebuilding.I've cleared all the passageways except for one, for which I tried carb spray, compressed air, and soaking for 20 hours in Berryman CarbDip.But now I'm thinking that maybe it is not suppposed to be a clear passageway. Can anyone tell me?It is an air inlet, labelled "A" in picture one. It appears to travel down to the Pilot jet tube "C". It is clear all the way to where the pilot jet tube is, then deadends a few mm from the tube.I don't see "light at the end of the tunnel (passageway)" when I put light in the pilot jet tube.Is this passageway supposed to be clear or blocked? In pic two, I labelled the passageway "B".
You can just call me Dude.
Syracuse, New York
Syracuse, New York
Replied by MarkT on topic DT3 (also DT2) Carb rebuild: Clogged Air Passageway? VM26SH
The center passage is the "air bleed" to the needle jet.
The passages to each side are for the pilot circuit... which one is used depends on which side of carb has the idle air screw. On your carb, the idle air screw should be on the left? So "A" would be blanked internally.
22 Feb 2021 12:38
I looked at your picture closer and it looks like the left passage is blocked by a brass ball?
That probably means Yamaha/Mikuni tied the right side idle air passage to the center air bleed. This was done on some models as a form of "fine tuning".
(Some models had the idle air passage connected to an external fitting... but that was rare and I don't think I've seen in on an enduro.)
22 Feb 2021 14:39
- Yamadude
Replied by Yamadude on topic DT3 (also DT2) Carb rebuild: Clogged Air Passageway? VM26SH
Thanks for your replies Mark, You seem to be clarifying some of the head scratching I've been doing in regards to the configuration of this carb, which my Clymer manual does a poor job of. Yes, the air screw is on the left side, see diagram below, #36. And yes, the left air inlet is blocked from the factory with a brass ball bearing. And when I screw in the air screw, the tip of the screw can be seen entering the center passageway. So, am I correct that when I spray carb cleaner into the right inlet "A", the liquid should squirt out into the Pilot tube "C"? At the moment, it doesn't squirt anywhere, just builds up in the passageway.
Syracuse, New York
Syracuse, New York
- Yamadude
Note that I corrected my last entry by saying that : " And yes, the left air inlet is blocked from the factory with a brass ball bearing."
Syracuse, New York
Syracuse, New York
22 Feb 2021 15:07
No, you are not correct. As I said above, the right inlet should be blocked as air screw is on left side.
Left inlet should connect to center passage very near back of carb. That left passage goes past the air screw and connects to the pilot tube "C".
The brass ball makes it harder to test the left passage... I've known people to remove the ball to make sure the left passage is cleaned out. Leaving the ball out doesn't seem to make a significant difference in running according to someone I know that "does it all the time". I haven't tried it.
The following user(s) Liked this Post: Yamadude
22 Feb 2021 17:58
Maybe this helps... if the air screw was on right side of carb, then the right side passage would be open to the pilot well and the left side passage would be blanked.
22 Feb 2021 18:00
- Yamadude
OK, cool, I'm getting it; the right passage should be open at the intake side (as it is) and blocked at the front of the passage (as it is). Therefore, when I've shot cleaner into and it just fills up with fluid, this is as it should be, yes?
Syracuse, New York
Syracuse, New York
22 Feb 2021 18:13
Yes, exactly. It's not in use.
The blank carbs have the passages for either a left or right air screw.. which passage is machined to connect to the pilot well is determined by which side of the carb is machined for the air screw. The other passage is a dead end.
- Yamadude
Mark, you have been exceptionally helpful ! Thank you. I have printed out your responses to add to my file on this bike. I can't wait for the snow to melt to do the next road test.
Syracuse, New York
Syracuse, New York
22 Feb 2021 18:26
