Rectifier location
  • Zeph
  • Zeph's Avatar Topic Author
Rectifier location was created by Zeph
Hey Guy's,  I have a 73 DT250
I'm trying to sort out, the wiring has been a bit of a mess, and had been somewhat hacked by the PO's.  The manual I have doesn't do a great job of locations of devices.  Is the rectifier located just above the coil in the top front "corner" of the frame?  I believe thats what is left of one in that location on mine.  Thanks so much, ready for Spring..................
Last edit: 21 Feb 2021 13:56 by Zeph.
21 Feb 2021 13:48 #1
Replied by MarkT on topic Rectifier location
Should have a white wire in and a red wire out if that helps
21 Feb 2021 14:45 #2
Replied by JimA on topic Rectifier location
That is ware it is located on my 75 DT 175, but I am not sure about the 250.
21 Feb 2021 22:32 #3
Replied by Bigdog302 on topic Rectifier location
They are usually under the fuel tank. you will need to remove the fuel tank to get at it.
Dave
Jesus is Lord!
21 Feb 2021 23:13 #4
Replied by Gr8uncleal on topic Rectifier location
Yes.
21 Feb 2021 23:37 #5
Replied by JGersh on topic Rectifier location
Should be located here...
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
The following user(s) Liked this Post: Rick C., MarkT, Bigdog302
21 Feb 2021 23:50 #6
  • Zeph
Replied by Zeph on topic Rectifier location
Awesome help guys, thanks so much
The following user(s) Liked this Post: MarkT, JGersh
22 Feb 2021 05:13 #7
