piston search
- RobertE
piston search was created by RobertE
Need some help here. I am having a hard time locating a 2nd over piston and rings for my 73 dt250. Everything I see on ebay shows 74 to 78 not being compatible with the 73 model. According to part numbers, they are the same for all those years. Question is, will a 74 piston and rings work for my 73?
22 Dec 2020 14:26
- yamahahaha
Replied by yamahahaha on topic piston search
If you do in fact have a 1973 250 it is called a DT3 NOT a DT250. Try searching DT3 for your piston. Go to Tech Library above and click on to Vin search to verify what you do have
22 Dec 2020 15:03
Replied by MarkT on topic piston search
You could also try contacting Enduronut... he has a good supply of OEM pistons and rings for sale.
22 Dec 2020 15:09
- RobertE
Replied by RobertE on topic piston search
This is very interesting. The vin # confirms it to be a DT3. Upon ebay search for piston and rings, it shows several pistons for Dt3, but also indicate they can be used for 74 to 76 Dt250. It makes me wonder why pistons listed for dt250 don't show compatibility for the DT3. At least, I'll be able to get the correct piston. Much thanks for the info.
22 Dec 2020 17:26
- Rick C.
Replied by Rick C. on topic piston search
Try using the part number . 308-11636-01-00
22 Dec 2020 17:49
Any chance you could post a link to a piston on ebay that you're describing?
I did a quick look and pretty much all showed they fit the DT3 and the 74-76... I didn't see any that didn't.
Wondering like you're doing is a good thing... a lot of things aren't listed right on ebay and you don't want to end up with something that won't work.
22 Dec 2020 18:07
Replied by Gr8uncleal on topic piston search
Both CMSNL and Partzilla show the piston as fitting 250 bikes from 1972 - 1976 inclusive. Interestingly, they show the part number as 438...... - ie the code for the 1974 DT250A, so probably a supersession (or a mistake?!
). Hopefully Enduronut, DEET etc will read and confirm either way.
Replied by RT325 on topic piston search
308 sounds like a 360 piston. that'd make it fly--except the fins would fall off.
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=124091949895&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Bartman512
Replied by Bartman512 on topic piston search
Pretty sure Wiseco makes one. I had to bore my jug 4 over and that was the only piston I could find.
27 Dec 2020 05:30
