Upgrade for Powerdynamo (Vape) ignition
- Franjo
Upgrade for Powerdynamo (Vape) ignition was created by Franjo
Hi there!
I like the powerdynamo ignition which I bought in 2016 for my RT. Warm bike needs one kick, cold bike needs three and the 12V light is nice. But I was not very satisfied with the idle after the conversion. Too often the engine simply quit during idle. Especially when it was hot. Changing the pilot jet was also unsuccessful. Only raising idle to over 1600rpm made an improvement. But I didn’t like that and it started less good.
Some time ago here I read about a heavier alternative flywheel from Powerdynamo. But that is quiet expensive. So I decided to raise the weight of my lighter Powerdynamo flywheel to the weight of the origin Yamaha flywheel.
From a part of a huge steel tube and with a little help of my lathe I fabricated a steel ring which snugged over the Powerdynamo flywheel. I secured it with JB Weld. Now I’ve three seasons with it. The idle now runs with 1400 rpm.
Unfortunately I’ve forgotten the weight different between the Powerdynamo and the Yamaha Flywheel. But I think it was about 400grams (14oz).
With regards
Franjo
With regards
Franjo
The following user(s) Liked this Post: 2fishkev, RT325, KJB, JayB, Gr8uncleal
03 Dec 2020 00:36
Replied by Gr8uncleal on topic Upgrade for Powerdynamo (Vape) ignition
Very ingenious, and with a long term test to back it up.
Have you given feedback to the manufacturer?
03 Dec 2020 01:39
Replied by RT325 on topic Upgrade for Powerdynamo (Vape) ignition
Good idea. I also have a brass overlay one on one of mine & makes a nice lazy but still powerful motor. Mine is extra weight on top of an original 360 flywheel.
03 Dec 2020 02:10
- JayB
Replied by JayB on topic Upgrade for Powerdynamo (Vape) ignition
One thing to know is that the 'moment of inertia' is proportional to mass times the distance to center squared. So while the weight you added to the new flywheel totals the same mass as the original, the added weight is farther from the center than the stock flywheel. So you are probably getting more flywheel effect than stock, even though the weight is the same.
But what is important is that you are happy from a seat of the pants perspective and you solved the idle problem! Good job, thanks for sharing! I may copy you if I have the same idle problem, which is the most sincere form of flattery!
The following user(s) Liked this Post: Midlife Motor
03 Dec 2020 05:56
- mdscott
Replied by mdscott on topic Upgrade for Powerdynamo (Vape) ignition
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
The following user(s) Liked this Post: Franjo
03 Dec 2020 17:37
Replied by MarkT on topic Upgrade for Powerdynamo (Vape) ignition
Good point on the Moment of Inertia but pretty sure Powerdynamo flywheel is smaller OD than stock flywheel as well as being lighter.
When I was working with the original Powerdynamo, they had several flywheels and weights that all worked with the same stator... At least 3 different ones. One of them is about 4 pounds. I tested the two lighter ones for the 175's.
The way it worked was they would make up the kit with the dimensions and such that a customer requested... including flywheel weight. Any of the flywheel weights could be machined to fit the crank and the same stator was used for all. The very lightest flywheel had smaller magnets so less lighting wattage and had a different CDI box to match the smaller magnets. (Different size capacitor was used in the CDI box) The medium and heavy flywheels had same light output and CDI box.
I don't know about now that VAPE has taken over but when Edgar owned the company you could ask for any of the (at least) three flywheel weights that were available. I'm pretty sure the 360 has a medium weight and there is a heavier one you might be able to order.
03 Dec 2020 17:56
- mdscott
Flywheel DT.
When I bought the vape for my Bultaco there were two flywheels available.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
- Franjo
Replied by Franjo on topic Upgrade for Powerdynamo (Vape) ignition
In the past I bought about 7 or 8 of these ignitions (72 38 799 DC) from Edgar. He told me that I can also use the heavier version (73 45 799 00) of 1,9kg which they offered for the TY250. But this version was about 100$ more expensive. The 72 38 799 AC was made for alternative current and use without battery.
Also had one for a Kawasaki 500 H1 from them and for several Yamaha XT's. The flywheel for the Kawa looks pretty much like the ones we use on the DT/RT's. But the cones naturally are machined different. I think they don't make so many different flywheels there. Only make the cones different.
I attach the photo from the old Powerdynamo page which was taken over from Vape after Edgars disease:
www.powerdynamo.biz/deu/systems/lists/yamaha.php
But to be honest ... they were always produced by Vape in Czechia. And Powerdynamo was their best Distributor settled in Germany.
05 Dec 2020 01:55
