rt3 360 restoration help
- newbees
rt3 360 restoration help was created by newbees
hello ive bought a yamaha rt3 to restore im no mechanic but ive messed with bikes in the past striped it down to the frame and started stripping the engine .when ive took of the clutch cover of ive noticed loads of bits in the botom of it ,i assumed metal some part chewed up i thought then i found a small rock in there about 20mm square and then more smaller ones about 5mm to 10mm behind were the gearstick comes through cant see how they got in there no holes in casing any one got any ideas ill put some pics on later if anyone interested might be something obvious wen i take the clutch of thanks
22 Nov 2020 02:58
Replied by RT325 on topic rt3 360 restoration help
Gosh, Welcome, but sounds like you have a few issues to sort. Pics of the offending parts would be great when you can. Sounds like possibly to do with the kick start gears & possibly the bearing in the case behind the kick intermediate gear--idler gear call it. Then again if by 'rocks' you 'mean' rocks, small stones, i wonder if its been sabotaged by putting stuff in the oil filler hole. Hope not. Gonna be interesting. Goodnight from NZ down under. Well, 1.50AM damn it, this site is too addictive haha. Lucky i'm retired. Cut my teeth on these old girls back in the day working in the local Yamy shop. Still learning though.
22 Nov 2020 04:53
- newbees
Replied by newbees on topic rt3 360 restoration help
hello thanks for your reply here are the pics one with 10mm spanner showing size of bigest stone dosent seem to be any damage done as i can see
22 Nov 2020 09:23
- newbees
heres some with the clutch of still cant see how they got in there i put the big stone back i place to show were it was definatly gona be more pics and other questions gona try snd get those cogs out and split the cases next and ive not got a clue thanks
22 Nov 2020 09:34
- RT360Fan
Replied by RT360Fan on topic rt3 360 restoration help
Wow.
First, welcome!
Second, HOLY ROCKS batman! I have no idea why or how those rocks got in there, I've never seen anything like that.
Splitting cases is not that difficult, but can be intimidating the first time. Look in the Tech Section here for factory service manual, and various threads about rebuilds. Good luck, and keep us posted!
First, welcome!
- Pete-RT1
Replied by Pete-RT1 on topic rt3 360 restoration help
As Fred Flintstone would say that looks like Barney Rubble.
Amazing! Good luck with the restoration.
Yamaha CT1 007
Yamaha CT1-B The Doppelgänger
22 Nov 2020 10:08
- Pedalcrazy
Replied by Pedalcrazy on topic rt3 360 restoration help
Pretty obvious now how they got in there....confirms my original thought...sabotage in through the oil fill hole.
22 Nov 2020 12:21
Wow. I wonder--previous owner went to lunch halfway through an oil change. Child come along, sees a hole & tips all his rocks out of the fish tank in there. Owner comes out unaware & pours oil in then carries on riding. Be good if you could confidently wash it out without having to dismantle any further.
The following user(s) Liked this Post: shyted, Snglsmkr
23 Nov 2020 00:09
- newbees
hello thanks for all the replies and welcoming me to the forum i think the same either sabotage or just some kid playin the bike was imported from the usa to the uk and must have been stored outside it is covered in rust my next question is how much more do i need to take of before attempting to split the cases thanks
23 Nov 2020 11:16
- t-bone
Replied by t-bone on topic rt3 360 restoration help
One thing is the counter shaft sprocket needs to come off.
23 Nov 2020 14:29
