clutch push lever assembly
- Zeph
clutch push lever assembly was created by Zeph
Hey, does anyone know of a source for the clutch push lever for a 73 DT250? I'm not sure if other Yamaha model assemblies will work. Thanks so much
03 Nov 2020 15:33
- 1971DT250
Replied by 1971DT250 on topic clutch push lever assembly
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=253741177753&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Zeph
Replied by Zeph on topic clutch push lever assembly
Thanks so much, that's what I was hoping
03 Nov 2020 17:09
Replied by RT325 on topic clutch push lever assembly
That's good info to have. Not cheap, but!!.
04 Nov 2020 00:43
Replied by Gr8uncleal on topic clutch push lever assembly
+1
Interesting that the "-01" version is metal and has four "protrusions" at the top instead of three - I would have thought that this would have warranted a change of part number.
04 Nov 2020 01:14
- 1971DT250
Yes that will happen to the nylon sitting on a shelf after 50 years. I believe the ones from speedandsportinc.com were made in the early to mid '80s. The ones I bought recently were not cracked.
04 Nov 2020 11:10
- Hammer
Replied by Hammer on topic clutch push lever assembly
Zeph,
First, search for parts for a DT-3, NOT a DT250. That designation stated in 1974, along with a new frame, etc. From 1968 - 1973, they were DT-1/2/3 and RT-1/2/3. That should make it easier for you. Also, you might consider any of the several conversion to other actuators discussed on this site. We've ALL been through it. I made the change, and have NEVER regretted it, and will never have a non-working clutch because of it. Do a search on here for "Clutch actuators."
Here's from an old text:
See one of the many "clutch actuator" threads on this site. These will explain both the problem, and permanent cures, if you want them gone forever. You CAN get repops of the whole actuator if you'd prefer, but these use the same plastic actuator, and they will crack, it's just a question of "when." Search Clutch actuator in the subject search with an author of Hammer and you'll find them. The mod was one of DEET's design, and HE deserves ALL the credit. I haven't even so much as done anything to mine since I did the mod back in 2013 or so.
Hammer
Hammer
The following user(s) Liked this Post: MarkT, 2fishkev, Bigdog302, nhsteve
05 Nov 2020 00:29
- Zeph
Thanks Hammer, I didn't know about the conversions, I'll do a search
08 Nov 2020 13:18
