Slide sticking or Sticking Slide
- bradocross
Replied by bradocross on topic Slide sticking or Sticking Slide
This is a Mikuni slide as it does have the Mikuni symbol next to 2.0
17 Sep 2020 09:02
#11
- bradocross
I had tried some light sanding without success. I coated the slide with magic marker as suggested by HunterDave and found that the carb barrel had slightly "ovaled". I sanded the high areas and voila, it slides up and down easily now. Thanks Dave and everyone else who responded.
Hopefully I didn't oversand...........
The following user(s) Liked this Post: MarkT, DaveHunter
17 Sep 2020 10:11
#12
- yamahahaha
Replied by yamahahaha on topic Slide sticking or Sticking Slide
What grit paper did you use??
17 Sep 2020 14:46
#13
Replied by RT325 on topic Slide sticking or Sticking Slide
Be careful sanding down there as the guide pin sticks out. Great though if it's now sorted. Heavier spring for safety might be a good idea as the spring is very light due to having the oil pump spring to contend with as well when twisting throttle.
17 Sep 2020 15:04
#14
- bradocross
320 grit then 600 grit
17 Sep 2020 17:38
#15
