69 dt1 250 clutch cable length
- gusto
69 dt1 250 clutch cable length was created by gusto
iv tryed 2 clutch cables and both seem to be about half a centimeter too long. my worm cover is a little different as it only covers half the drive gear. im worried is it my cover thats the issue? i made a little washer type spacer that slid onto my cable where the other spacer thing is. its not ideal though because now the cable kinda scraps the cover. anyone else have hell with the ebay dt1 cables? i guess im gonna have to shorten cable another way in long run. thanks
- pahiker
Replied by pahiker on topic 69 dt1 250 clutch cable length
Have you tried a cable from KDI repros? They make quality products for these bikes.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
2024 Suzuki DR650
29 Aug 2026 04:03
- gusto
Replied by gusto on topic 69 dt1 250 clutch cable length
the ebay ones are kdi. my cover kinda dips down where the cable hole is so maybe its my cover. ill try and take a pic. i want to learn to solder my own but honestly the motion pro solder brass ones are expensive. i got some screw up kind coming. know if you can you desolder nipples on the cable and reuse them? know if you can solder the screw up nonsolder kind for extra strength?
29 Aug 2026 13:04
Replied by MarkT on topic 69 dt1 250 clutch cable length
Many KDI cables have been installed so trying to shorten one sounds like it could be a "band aid" fix to a problem with the plastic worm gear slipping on the shaft that might leave you stranded someday soon?
It's also possible the gear is engaged a tooth off?
29 Aug 2026 17:21
Also are you sure you didn't lose the ball for the clutch pushrod when you were messing with the clutch? Pretty common thing to happen.
#13 in the diagram. www.partzilla.com/catalog/yamaha/motorcycle/1969/dt1b/clutch
29 Aug 2026 17:29
- gusto
99 percent sure ball is in there. thx i got a brass worm gear to install but when i had it apart installing it was over my head so i think plastic one still works fine althought dont know why they put something so cheap in there. see how my cover is not flush at top when screwed up tight? and then theres like a little dip in cover where clutch cable goes threw. i put a little spacer on end of cable you can see in pics. its only like half a centimeter. was there something extra on my cover like a gasket or something metal where the clutch cable hole is that would create a half centimeter?
imgur.com/a/JGHIhKs
imgur.com/a/JGHIhKs
30 Aug 2026 22:13
- pabdt
Replied by pabdt on topic 69 dt1 250 clutch cable length
An observation:
Your chain cover appears to have slipped under the serial number plate area. Its hard to tell as my own bike has a cutout there. The red line in photo is the point of contact for the cover and L case. Of course, this would make you use less adj, so that doesn't make sense I guess.
I would also wonder if the clutch pressure plate is pushing L and your cover is twisting R as actually there is no supporting mount on the rear of the cover.
See if this helps. As I look closer at my own cover, I find the prev owner put a spacer at the end of the cable. LOL, works for me. I guess I just found out!
Misery loves company.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- gusto
oh wow im not first to put a spacer on. that cover looks like it might be higher at where the cable goes threw. i just need a 3/8 inch difference. we just made a better spacer that i taped up to the cable sleeve. i was going to do own cables but yet to make a bird cage tool for the cable ends.
02 Sep 2026 11:12
- gusto
in japanese they say it like space-a
02 Sep 2026 23:35
- Schu
Replied by Schu on topic 69 dt1 250 clutch cable length
In Canadian they say it like space eh!
Sorry sorry. I just couldn’t pass that up.
03 Sep 2026 18:55
