AT3 -> CT3 Engine Conversion
  • cookdlobsta
  • cookdlobsta's Avatar Topic Author
AT3 -> CT3 Engine Conversion was created by cookdlobsta
Hi,
I'm currently building a Yamaha AT3 Frame I bought at a junk yard. Basically I want to get some reassurance on what I have found on Google and some additional insight / guidance going forward. From what I understand AT1 2 & 3's are nearly identical to the CT series & DT 125's.
The frame I found has a 1973 AT3 engine with a 171c header and piston, I'm assuming it came from a CT series. I took the original engine apart and the innards look pretty nice, considering it was in a yard for some time (pic 2). The dynamo assembly itself is a pain in the ass, and there aren't many videos / articles on the web that cover it. Plus, I would rather switch to a static stator & rotating flywheel for many reasons.
My big question is, if I have a AT3 engine, can I buy a CT3 175 crank case and migrate everything (innards) over? Buy a stator / flywheel, find the correct crankshaft, ect.
Pic 1: Frame
Pic 2: Clutch Side
Pic 3: Dynamo I want to change (the whole reason for this)
Appreciate anything y'all can give me!
This is what I'm working with:
I've restored a couple vintage vehicles:
71' F150 Long Bed
76' CJ7
Now I want a bike.
Last edit: 31 Mar 2019 14:46 by cookdlobsta.
31 Mar 2019 14:45 #1
Replied by MarkT on topic AT3 -> CT3 Engine Conversion
You just need a 1969-73 CT crankshaft and of course the ignition (stator and flywheel).
Crankcase is the same on the AT and CT.
The following user(s) Liked this Post: cookdlobsta
31 Mar 2019 15:04 #2
Replied by RT325 on topic AT3 -> CT3 Engine Conversion
I should know--but think--the left case has a different way of mounting the generator stator whatever ya call it, compared to the flywheel stator. Just check it out. I'll go look on partzilla if drawings are clear enough. --Had a look at AT3 & shows the generator & magneto in the same pic & only one crankcase in other pic so i must be wrong--again lol. Not in same pic but says Magneto & also says Generator then in crankcase link only shows one option. Top end swaps over ok. AT1 [piston port motor] has a different conrod length but AT2 & 3 just swap CT2 & 3 175 top end. I've got a TY175 top end on my piston port AT1 magneto model but think i added a base plate--must go look, too long ago. 175's go very well. Link below if it works. Rough old think we've had as a farm bike since the mid "70's as a trade-in at work. Clutch cover has never been off it. Sorry to woffle on, on your page. Have super high road gearing on it these days.
www.partzilla.com/catalog/yamaha/motorcycle/1973/at3
www.partzilla.com/catalog/yamaha/motorcy...3/crankcase-cylinder
Last edit: 31 Mar 2019 15:55 by RT325.
31 Mar 2019 15:28 #3
It was the 250 that changed the rod length in 1972 when they went to reed valve... 125 and 175's have had the same rod length from 69-81 both reed and piston port.
31 Mar 2019 16:19 #4
Ok--umm, maybe i was trying to run an RX125 top end which has the super tall piston & is 5mm taller from pin to top. Never mind, so long as OP's works.
31 Mar 2019 17:09 #5
  • cookdlobsta
Replied by cookdlobsta on topic AT3 -> CT3 Engine Conversion
This is super helpful, thank you!
71' F150 Long Bed
76' CJ7
Now I want a bike.
31 Mar 2019 18:01 #6
  • cookdlobsta
Okay, so just to verify?
These styles will work:
This style will not:
71' F150 Long Bed
76' CJ7
Now I want a bike.
31 Mar 2019 18:28 #7
1969-1973 CT will work.
The 175 had a major redesign in 1974... the primary gear end of the crank went from "splined" to "keyed" so even though a 1974 DT175 crank might work, you'd at least need the crank gear too... and maybe other parts. Best to stick with a 69-73 CT1 crank.
A 250 crank will not work in a 125/175.
Be careful of cranks that show any rust... if the big end bearing got rusted at all it will fail quickly. Unless you are rebuilding the crank anyway.
31 Mar 2019 19:12 #8
Replied by Hondarsw on topic AT3 -> CT3 Engine Conversion
Powerdynamo/Vape offers a modern CDI for the AT series motors.  Mine works great and have never missed the electric start option.  One kick and were ready after brief warm-up.  CT barrel and pistons is all you need for the conversion.  Thats all I needed on mine.  You may need to rejet, depending on elevation.
09 Sep 2021 09:46 #9
Need head too. Mind you machine a 125 head out to 66mm at the edge & she'll be a high comp head--got me thinking now with my conversion haha.
09 Sep 2021 15:20 #10
