Cracked gas tank repair
  • srsnow
  • srsnow's Avatar Topic Author
Cracked gas tank repair was created by srsnow
The tank on my 74 DT125 has a crack in the bottom right below the filler neck, I tried some JB weld for gas tank but it didn't work still leaks. I thought about trying to solder it but worried about gas fumes even if I flush it with water before hand. Anyone had luck fixing a similar crack?
09 Jan 2023 19:00 #1
Replied by Gr8uncleal on topic Cracked gas tank repair
Was that with silver solder, Simon?
10 Jan 2023 09:46 #2
Replied by MarkT on topic Cracked gas tank repair
I think I have it sussed... Simon says standard solder not silver solder seals steel seeps.
(Sorry, couldn't resist)
The following user(s) Liked this Post: Rick C., Swoop56, shyted, Gr8uncleal, Ht1kid, Pete-RT1, goatboy56
10 Jan 2023 15:38 #3
Replied by darinm on topic Cracked gas tank repair
I had an AT tank leaking in the rear bottom corner, had someone TIG weld it and it's been great.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
10 Jan 2023 16:49 #4
"Simon says standard solder not silver solder seals steel seeps."
10 Jan 2023 23:51 #5
  • YamahaForumUsername
  • YamahaForumUsername's Avatar
Replied by YamahaForumUsername on topic Cracked gas tank repair
Aircraftspruce.com sells a tank sealer for you guessed it, airplanes. www.aircraftspruce.com/catalog/appages/g...r.php?clickkey=11739 . Using silver solder plus this stuff will seal anything. Suprised there isnt an infomercial about this stuff.
11 Jan 2023 10:57 #6
Replied by shyted on topic Cracked gas tank repair
I have a spare 69 DT 1 tank that needs repair so i'm going to try TIG with16th silicon bronze rods.
Only because there's a split on the top welded joint where it's cut away for the head stock and it needs building up a bit and reprofiling.
I think solders a good idea as very little heats required.
11 Jan 2023 16:18 #7
Replied by Pedalcrazy on topic Cracked gas tank repair
I’ve had a couple DT tanks repaired by the local welding shop. I figured they would braze it but he said TIG would be perfect for it. That process is very precise and not destructive. I’ve MIG welded a little on seams too which worked great. I think a problem with the repair technique is if it leaks because of rust. Super thin metal is the enemy for sure.
12 Jan 2023 15:06 #8
I agree on that.
The good thing about using solder is, providing everything is clean, you get good capillary action so better odds of getting a good seal first time and it don't come off.
TIG is good due to less heat over the use of MIG. The process is a little harder as you have to have a cloud of Argon there all the time , before, during and on completion and of course, you're feeding the rod in and keeping your arc gap as steady as possible. The result is better if you can do it or get it done for you.
12 Jan 2023 16:44 #9
  • srsnow
Replied by srsnow on topic Cracked gas tank repair
thanks for the input guys, for those who have a shop weld it up did it damage the paint?
12 Jan 2023 20:27 #10
