Fun With Oil Pumps
- apex
- Content Contributor
Fun With Oil Pumps was created by apex
The oil pump on my DT1C has been leaking since I got the bike, but of late, it's been leaving puddles of "my injector oil of choice." Mind you it works just fine, just is puking oil past the seal next to the plastic wheel.
Ordered a rebuild kit from hvccycle.net. Upon removing the cap, you can imagine my surprise when I saw this!!
Allrighty Then
28 Dec 2020 11:21
- Mothersbaugh
Replied by Mothersbaugh on topic Fun With Oil Pumps
More teeth missing than a banjo player at a hootnanny...
The following user(s) Liked this Post: mdscott, darinm, Pete-RT1
28 Dec 2020 12:34
Replied by RT325 on topic Fun With Oil Pumps
Gosh. Says a lot for premixing.
28 Dec 2020 13:18
- LETSJET
Replied by LETSJET on topic Fun With Oil Pumps
Pretty hard to kill an oil pump but you got close. Probably got your money's worth from it.
28 Dec 2020 14:02
- Swoop56
Replied by Swoop56 on topic Fun With Oil Pumps
On the positive side , there are still replacement worm wheel gears about .
28 Dec 2020 16:12
- DEET
- Moderator
Replied by DEET on topic Fun With Oil Pumps
Since most folks believe the pumps are interchangeable and give no thought to the ring gear/worm gear compatibility requirement, it is not surprising to see the damage. The damage didn't occur because the teeth failed in normal use. The worm gear pitch was different so it ate up the ring.
Of course, that's just my opinion.
The following user(s) Liked this Post: MarkT, Blackhat250, RT325, Swoop56, JGersh, asco, Snglsmkr, KennyV, AirborneSilva, Jack
- Midlife Motor
Replied by Midlife Motor on topic Fun With Oil Pumps
I have an oil pump in good shape from a DT1C I am parting out if you are interested. Text 480 797-7716. Sean.
29 Dec 2020 06:34
- apex
Replied by apex on topic Fun With Oil Pumps
In this bikes case I have no history before last spring. Pump was on, but appeared not to have been used for some time, since the oil tank window was gone, pump discharge hose was disconnected and a bolt in the cylinder inlet port. Oil pump looks original, clutch cover looks undisturbed, but, who knows?
I was thinking this was damage that may have happened when I first fired the bike up on pre-mix, the base of the shaft where the plastic gear resides was pretty corroded, so thinking maybe the pump shaft was resistant to turn and/or seized at initial start up? I plumbed the oil pump shortly after getting the bike running, and pump was leaking a little past the seal by the plastic wheel right away, and only worsened over the past few weeks. Pump worked as soon as I plumbed it, and I've put about 1000 miles on the bike up to opening the pump up and finding the damaged gear.
Anyway, thanks to Midlife I have some DT1C pump parts headed my way. THANK YOU!
I will be pulling oil pumps prior to engine fire up with future resurrections, just in case.
Allrighty Then
31 Dec 2020 10:11
- DEET
- Moderator
Another possible failure scenario would be that the internal cylinder stopped spinning freely and the worm gear ate the ring gear.
That can happen from rust or debris inside.
31 Dec 2020 12:14
Replied by MarkT on topic Fun With Oil Pumps
The following user(s) Liked this Post: Snglsmkr, JimA, Schu, Pete-RT1, bosco659
31 Dec 2020 12:23
