DT400 Revs Hanging
  • hatrick1960
  • hatrick1960's Avatar Topic Author
DT400 Revs Hanging was created by hatrick1960
Hi,
This has probably been covered before but my DT Revs 'hang' and then drop back down again if I pull the clutch in?
Also should you b e able to 'red line' these bikes, I struggle to get past 6K?
16 Dec 2021 05:08 #1
Replied by Pedalcrazy on topic DT400 Revs Hanging
Others will come along I’m sure but…I think folks here will say you may have a small air leak somewhere. Could be rubber intake manifold or crank seals. I have both a DT400C and DT400E and will red line in lower gears. Top gear would be 80+ MPH and haven’t gone there! I recall some of the experts saying the big bores don’t like revving out and I agree.
16 Dec 2021 08:34 #2
Replied by GaryDean on topic DT400 Revs Hanging
Hi
Ive recently had this issue and there is a recent thread on it on this site. basically I did all the usual checks, seals inlet manifold etc, ignition system. my problem was the carb, it had the wrong jets it, I cleaned the carb, went back to stock jets and set the idle mixture jet at 3/4 of a turn out instead of 1 1/2 turns and problem went. the bottom end is a little gurgly but no hanging or over run, its a small price to pay
16 Dec 2021 08:36 #3
  • hatrick1960
Replied by hatrick1960 on topic DT400 Revs Hanging
I actually took the bike to a 'two stroke' specialist and they checked the carb out and said everything is as it should be - correct jets etc and all clean. He said definitely not crank seals so I'm guessing maybe the rubber inlet from the reed valve to cylinder head?
Is it worth putting after market reeds in?
Last edit: 16 Dec 2021 09:59 by hatrick1960.
16 Dec 2021 09:57 #4
Replied by Blackhat250 on topic DT400 Revs Hanging
Spray easy start  around carb boot etc, or remove  flywheel cover spray at crank seal area,  [ bike running ],,  soon see ,
If you aint mixin gas " you aint haulin Ass
16 Dec 2021 11:57 #5
Replied by Jammyyammy on topic DT400 Revs Hanging
One of the air leaks on my DT400 was where the two crankcase halves join together - near the front engine mounting.
16 Dec 2021 16:07 #6
  • hatrick1960
How did you find the leak?
17 Dec 2021 05:33 #7
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic DT400 Revs Hanging
It's not something daft like a sticking or incorrectly routed cable, is it?
17 Dec 2021 06:53 #8
Replied by msavitt on topic DT400 Revs Hanging
air leaks bad!
17 Dec 2021 08:27 #9
I put carbon reeds in mine as the thought of 47 year old stainless ones being case hardened going into the pot would be a bad day
17 Dec 2021 08:31 #10
