Wanted DT1 44T Rear Sprocket
- swm
Wanted DT1 44T Rear Sprocket was created by swm
Need an original 44 tooth DT1 rear sprocket for a restoration. Very common from 1968-73, maybe other years. I have several but teeth are worn.
- asco
Replied by asco on topic Wanted DT1 44T Rear Sprocket
They have always been needles in haystacks they all wear out and nearly impossible to secure. I will check but most sprockets I have are CT1 and won’t work.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
15 Jul 2023 10:43
- swm
Replied by swm on topic Wanted DT1 44T Rear Sprocket
Asco,
Agree, easy to locate but not easy to find with good teeth.
Thanks!!
Thanks!!
15 Jul 2023 13:07
- shyted
Replied by shyted on topic Wanted DT1 44T Rear Sprocket
There's an ebay vendor in the States call mytrashyourtreasure. I bought 2 NOS ones off him a few weeks ago.They weren't cheap and i faced a bill of $450 plus shipping. Maybe see his ebay store. He maybe has something.
Dave
Dave
16 Jul 2023 23:46
- swm
shyted,
Good suggestion, they have great inventory of rear sprockets but none of the early 44T.
Much appreciated!!
swm
Much appreciated!!
swm
17 Jul 2023 10:52
- Dennis D
Replied by Dennis D on topic Wanted DT1 44T Rear Sprocket
Sprocket Specialist will make a sprocket for you and if you tell them you need it to look exactly
like that one they can and will make it. It will be an alloy, and you may need to send them your
old one to get measurements off of it.
The following user(s) Liked this Post: MarkT, swm
17 Jul 2023 12:28
- Swoop56
Replied by Swoop56 on topic Wanted DT1 44T Rear Sprocket
I faced the same issue when rebuilding my DT1 .
I bought a 520 44T sprocket blank , had the holes laser cut to match original pattern , and then had it zinc plated .
It was an expensive exercise , but worked out well . It looked perfect .
The following user(s) Liked this Post: swm, Tinkicker
17 Jul 2023 13:53
- nivlagusa
Replied by nivlagusa on topic Wanted DT1 44T Rear Sprocket
I got one at Dennis Kirk. Its black though.Parts Unlimited. 21425444 10. Part #8187445. $39.95
17 Jul 2023 14:09
- nivlagusa
I got one at Dennis Kirk. Its black though.Parts Unlimited. 21425444 10. Part #8187445. $39.95 Looks like you want a OEM match though.
17 Jul 2023 16:05
- swm
I appreciate the excellent suggestions. I'll reach out to Sprocket Specialist - I have couple Yamaha NOS 44T sprockets where the six holes are smaller diameter than what I need. If SS will simply enlarge holes to match the early 44T I'll be golden. Much appreciated!!
17 Jul 2023 18:30
