DT360
  • jsmith6752
  • jsmith6752's Avatar Topic Author
DT360 was created by jsmith6752
I am having problems with my wiring. I have a regulator inside my headlight housing with a ground wire and  a yellow wire that's not hooked up. Where does it go? I don't think my headlight works and I have no dash lights.I do have a brand new 6v battery
13 Nov 2024 17:25 #1
  • jsmith6752
Replied by jsmith6752 on topic DT360
I am totaley confused now. I already have a regulator inside my headlight with 1 yellow wire coming out bu5t not hooked to anything
13 Nov 2024 18:46 #2
Replied by RT325 on topic DT360
Hope you realize the lights run off the magneto so motor needs to be running.  Regulator yellow can go to instrument blue which feeds back to everything needing a voltage limitation, black from regulator body goes to any black that finds its way to earth or run a wire all the way to the coil mount under the tank which is where the main loom earth's out.
15 Nov 2024 12:52 #3
Replied by MarkT on topic DT360
jsmith-  some advice...  posting the same question over and over in multiple threads is a really bad way to proceed in my experience...  it will confuse the hell out of you and everyone trying to help.  And people will very quickly learn to ignore your questions as they start to appear "troll-like" and it seems like you're not even trying.
When someone responds and tries to help, best practice in my experience is to respond with more questions if you don't understand what they are trying to tell you.  Don't go off and start a new thread with the same question someplace else.  You've had some brilliant minds try to help you and they've given you exact and correct answers about the regulator you found in your headlight bucket multiple times already.  Time to start listening and asking clarifying questions if you don't understand what they are telling you.
I believe a link to the Yamaha "add on" regulator service bulletin was mentioned and even linked in one of the 3 or 4 other threads where you asked the same questions?  Here is the bulletin again  yamaha-enduros.com/index.php/service-bul...e-voltage-regulators
The following user(s) Liked this Post: RT325, Snglsmkr, Ht1kid, Sneezles61
Last edit: 15 Nov 2024 13:50 by MarkT.
15 Nov 2024 13:47 #4
  • jsmith6752
Thanks for your feedback I appreciate all the advice I have been getting. I am a little thick on putting all this together. My apologies.
15 Nov 2024 16:36 #5
All good.  Electrical can be especially confusing for most of us.
If you can use Imgur or other service to include pictures, that GREATLY helps clarify what you're asking/seeing and will also help people trying to help you give better answers.
15 Nov 2024 17:47 #6
  • jsmith6752
I registered  with Imgur.I have no clue as to how it works. Any tips? thanks
16 Nov 2024 05:25 #7
Replied by pahiker on topic DT360
Upload an image to imgur. Once uploaded, you can copy/paste the link from your imgur pic into your post. If you want the actual pic to show in your post, copy the bbcode in imgur from your pic and paste it into your post.
1973 Yamaha RT3
2024 Suzuki DR650
16 Nov 2024 05:33 #8
  • jsmith6752
I will give it a go. thanks
16 Nov 2024 05:51 #9
  • Reed valve Richards
  • Platinum Member
  • Platinum Member
Replied by Reed valve Richards on topic DT360
Go to imgur, once in click on your icon, click IMAGES, (you have none at first), then click on POST, drag your images and drop, then once images appear, click back on your icon and IMAGES again, click one picture, I usually choose the second to bottom bb code and it has been working ok so far, hope that helps.
Yo Joe, Go Joe
17 Nov 2024 01:01 #10
Moderators: yamadminMakotosunDEETVinnie
