1974 dt360a
  • Robs360
  • Robs360's Avatar Topic Author
1974 dt360a was created by Robs360
New to forum. Stumbled across a 1974 dt360a vin 446-014769, matching # on engine. It's just a roller with engine. Missing flywheel and cover stator and pulser appear to be bad, no continuity from either and stator was pitifully rusted though I was able to remove without breaking bolts. Autolube there but disconnected and cylinder plugged. Cover Missing over oiler also. I know about the vape system but before spending that much before I get it running and source correct fuel and oil tanks, what's the most economical way to source stator and flywheel, a points system from a dt250? Any suggestions on sourcing parts besides ebay? I'm about an hour south of kcmo everything scarce around me. Thank you for any suggestions. I am confident I can restore and get running if I can find parts.
The following user(s) Liked this Post: 2strokenewb
23 May 2024 16:21 #1
Replied by Ht1kid on topic 1974 dt360a
Greetings from Tennessee
23 May 2024 16:49 #2
  • Robs360
Replied by Robs360 on topic 1974 dt360a
Thank you ht1kid
23 May 2024 17:08 #3
Replied by RT325 on topic 1974 dt360a
Greetings from NZ. Stator source coil without looking should have about 350 ohms so need the scale cranked up on an annologue meter, i'm too old for digital.
Think those had just one brown wire from the sorcey thing.
Pulser would be white/green & white/red & you might need to touch one to earth then test the other to earth & visa-versa with other but don't quote me on that. I guess if that reads then should be also between those two wires.
Probably around 100 ohms. I'll look it up tonight. I'm just going by memory hoping you get a reading of sorts.
I'm using just the source & a suzuki plug coil cdi box combined unit & just one wire from source straight to the coil & works.
If all else fails then a late DT250 points mag from about "78 or a CDI mag from a "79 better cdi setup, or a DT400 from up near there--same better system after they ditched that dodgy pulser stator.
23 May 2024 18:45 #4
Replied by pabdt on topic 1974 dt360a
Calif. here. Post up pics if poss!
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
23 May 2024 22:38 #5
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 1974 dt360a
 from near Salisbury, UK.
My suggestion for the cheapest option would be to replace with a points system from a DT250. DEET here on the forum makes a plug and play mini loom conversion for the main wiring harness.
The following user(s) Liked this Post: Ht1kid, Robs360
24 May 2024 01:20 #6
  • Robs360
Thank you r325, I was electrician and have meters, they're both definitely bad
24 May 2024 04:36 #7
  • Robs360
Thank you Pabdt, I've actually been following your restoration. I'll have to figure out the pics thing. Like r325 said might try to source 250 ignition.  Not much there but bare roller and bare engine, surprisingly both brakes work fairly well
24 May 2024 04:42 #8
Replied by Sneezles61 on topic 1974 dt360a
Hi Rob, I’ll go look at my box of DT250A parts.. I may have the points and stator plate. You’ll have to decipher if it’ll work on yer 360. I’m in Mn by Duluth.
24 May 2024 05:54 #9
  • Robs360
Sneezles61, thank you that's very kind. I might have found a 75 dt250 that's pretty rough but having difficulty getting owner to respond. I think he just collects and junks scrap has no idea of year or condition won't give me serial #, going to look at this weekend if I can get him to respond. Surprisingly has a decent looking fuel tank though painted white. I will post if I can get it. Exhaust comes out on left side is why I think it might be 74 but not sure
Last edit: 24 May 2024 06:38 by Robs360.
24 May 2024 06:37 #10
