recomendations for descent case splitter
  • AirborneSilva
  • Platinum Member
  • Platinum Member
recomendations for descent case splitter was created by AirborneSilva
Hi guys, well after spending almost $1K on getting new seals/bearings in my CT2 an ugly issue popped up that I had feared would, somehow the previous owner screwed this thing up so bad that the kick starter wont fully disengage, not the shops fault.  So I have bought some used case halves off e-bay and instead of spending way too much money again I have decided I want to give this a shot but need the tool to split the case.  Thanks for any suggestions...
16 Mar 2026 07:46 #1
Replied by RT325 on topic recomendations for descent case splitter
The right side case will slide away off the crank & everything else will pretty much fall out. But ok you still need a way of getting the crank out of the left side as is tight, or should be tight. I guess ebay is the place to look but someone will have a link to one for sure.
16 Mar 2026 16:37 #2
Replied by pabdt on topic recomendations for descent case splitter
RockyMountainATV.com. Used this many times, twice recently on a CT1, a real quality tool.  The crank puller has another piece I don't see in their current pkg, you may need the adapter pkg for the puller too.  Not sure, but for $9.99 why not.  Fairly sure the top 2 will do it.
If you want Yamabond 4, they have that too and if you are really obsessed, get a bolt kit, about $32 on ebay.
Case Splitter
Crank Puller
Adapter Puller
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 16 Mar 2026 19:02 by pabdt.
16 Mar 2026 18:54 #3
Replied by MarkT on topic recomendations for descent case splitter
A common two-bolt puller can be used to split the cases.  Auto parts stores often "rent" them for free (i.e. steering wheel puller).  Pulling the crank back into the case properly is more of a challenge IMHO.
I have the tools already but if I didn't, I'd contact DEET.  He used to make a comprehensive set of tools that had all the adapters to properly reassemble any of these old enduros.
The following user(s) Liked this Post: DVM, AirborneSilva, nhsteve
16 Mar 2026 23:08 #4
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic recomendations for descent case splitter
Thank you all for the comments, links and suggestions. I swear this bike is cursed! I bought it from the dudes father because he had died of alcoholism so I'm sure the work he had done on the bike and the damage it/he caused is biting me in the butt!
17 Mar 2026 04:57 #5
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic recomendations for descent case splitter
Tony, hopefully it wasn't the bike that drove him to the bottle............?!
The following user(s) Liked this Post: MarkT, pabdt, AirborneSilva, Schu, Ht1kid
17 Mar 2026 06:26 #6
Replied by buckstrucks on topic recomendations for descent case splitter
The Tusk splitter and puller work great.
The following user(s) Liked this Post: pabdt, darinm, AirborneSilva, nhsteve
29 Mar 2026 13:37 #7
Replied by darinm on topic recomendations for descent case splitter
I'll second or third the Tusk, for the affordable cost it gets the job done well with no issues.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
29 Mar 2026 22:13 #8
Replied by nhsteve on topic recomendations for descent case splitter
I bought the DEET setup and it worked fine for rebuilding the DT1. I have an old Yamaha 2 arm puller from when I worked in the trade.
Don't forget that heat is a great assistant here. Warming the bearing inner race before attempting installation can really help ease the crankshaft into place.
31 Mar 2026 08:08 #9
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks for all the suggestions, I actually chickened out after talking to the shop that installed the bearings, seals and put it together. Before anyone says anything, the issue I'm having is NOT the shops fault. Anyway, he gave me a price I couldn't refuse to take it back apart, put the new (used right side case on along with bearings and what not. The price wasn't much more than the cost of tools I would need. Someday I will man up and do this myself but the issues I'm having with it I wanted to Pro to deal with it. Thanks again to all!
31 Mar 2026 08:29 #10
