1972 Yamaha ct2 175
- Dugadie9
1972 Yamaha ct2 175 was created by Dugadie9
Hi guys,
which piston ring goes on top the green one ?
which one goes on bottom ?
please help Frank
please help Frank
14 Sep 2023 18:19
- Visitor
Replied by on topic 1972 Yamaha ct2 175
Keystone ring goes on top. Wont fit in the lower groove.
15 Sep 2023 01:30
- Dugadie9
Replied by Dugadie9 on topic 1972 Yamaha ct2 175
Keystone is the green one
15 Sep 2023 04:46
- Dugadie9
15 Sep 2023 05:33
- Dugadie9
Gray ring
green ring
which goes where ?
green ring
which goes where ?
15 Sep 2023 06:02
Replied by MarkT on topic 1972 Yamaha ct2 175
A Yamaha Keystone piston normally (always?) has a "K" stamped into it. You don't want to put a keystone ring into a standard groove piston.
Yamaha rings normally (Exception: Dykes top ring) have a tiny "1" (top) and "2" (second) stamped into the top edge near the ring gap if they are different. Check for that. You'll likely need a magnifying glass.
There are so many mixed up ring sets and piston/ring parts changes over the years, it pays to be careful.
The following user(s) Liked this Post: Dugadie9
15 Sep 2023 06:03
- Dugadie9
Thanks you are awesome!!
15 Sep 2023 06:03
- Dugadie9
Do I use the expander rings ?
how do they go on underneath the main rings ?
15 Sep 2023 06:15
Here's a quote from the (piston and) ring master, Enduronut:
"The CT2 & CT3's models use expander rings underneath both top and bottom rings.
The yellow marked one goes in the top groove.
You'll also notice that it's a bit narrower then the bottom expander."
15 Sep 2023 07:46
- Visitor
Keystone rings wont fit into the wrong piston groove.
15 Sep 2023 09:28
