TEIKEI Y16p carb for JT2 & GT80
- AirborneSilva
TEIKEI Y16p carb for JT2 & GT80 was created by AirborneSilva
Hi guys, I did a thing yesterday (couldn't help myself), I bought a 72 JT2 and an 80 GT80. They both have great spark but I'm guessing the carbs probably could use a rebuild so I'm on the hunt for parts (preferably a rebuild kit), the JT2 carb is a Teikei Y16P and the GT80 carb is a Teikei Y16P-3, any and all help is greatly appreciated - as always!
21 Aug 2023 11:23
Replied by Gr8uncleal on topic TEIKEI Y16p carb for JT2 & GT80
All I can say, Tony, is well done
on the purchases, but good luck finding new, original TK parts!
21 Aug 2023 11:34
- AirborneSilva
Replied by AirborneSilva on topic TEIKEI Y16p carb for JT2 & GT80
Thanks Alan, the price was right so I just couldn't help myself. Yeah I fear you're probably right on finding parts or even good used TK carbs, so now I'm wondering if there's a good substitute replacement carb for both...
21 Aug 2023 11:54
Replied by MarkT on topic TEIKEI Y16p carb for JT2 & GT80
Check with Treatland. They have a lot of parts for little engines. Sign up with them and they email you sale codes several times a year
Mikuni VM18 or one of the Bing or DellOrto clamp-on carbs will probably fit? You might need to measure your carbs and give them a call.
www.treatland.tv/SearchResults.asp?Search=carburetor
21 Aug 2023 12:21
- AirborneSilva
Thank you Mark, that's a big help!
21 Aug 2023 12:55
Here's an older thread on this... I think Treatland has different size shims.
yamaha-enduros.com/index.php/forums/gene...ha-enduro-help#94514
21 Aug 2023 13:59
- AirborneSilva
Thanks again Mark, I'll have a look at the VM18. I haven't tried to take a look at the carbs on these bikes yet, my worry is even if they're not in bad shape the gaskets have got to be pretty bad at this point and will just leak.
21 Aug 2023 14:18
Maybe not. I try to reuse the original Mikuni gaskets if I can. They are way better than most new ones. If not torn, they swell up and seal again 99% of the time.
If you have the carbs they might be ok and you can always make gaskets.
21 Aug 2023 14:33
- Tinkicker
Replied by Tinkicker on topic TEIKEI Y16p carb for JT2 & GT80
Look out for TY80 and PW80 carbs also. Think they are the same. Also seem to very faintly recall that dellorto carbs off euro built honda Melody mopeds were pretty much the same size clamp on type if you get stuck.
The following user(s) Liked this Post: MarkT, AirborneSilva
- AirborneSilva
Thanks guys, I did get off my butt and pull the carb of the GT80, took it apart and to my surprise it really isn't all that bad inside but I do have it soaking and will let it soak over night. I did manage to get the gasket off without it breaking and was wondering if I let it soak in some lightweight oil if that might help it to soften up a bit.
Also, found the shim on this carb has a pretty good size chunk of it missing...
21 Aug 2023 15:21
