Spot the mistake.
- Tinkicker
Spot the mistake. was created by Tinkicker
In the piccy
The following user(s) Liked this Post: Enduronut, MarkT, asco
Replied by MarkT on topic Spot the mistake.
Pretty obvious, I won't ruin it. I can understand why it may have been done that way.
Good evidence as to why it's a bad idea to use parts diagrams for assembly.
28 Apr 2023 10:00
- DEET
- Moderator
Replied by DEET on topic Spot the mistake.
Hmmmm…. interesting!
If it wasn’t there would they know what to do?
Or would they blindly follow the diagram?
Would they question what was on the actual part?
28 Apr 2023 10:21
There is a contradiction in the drawing. It shows what is actually on the part correctly but someone possibly took "creative license" to show a feature that would otherwise be hidden? I've seen that quite a bit in diagrams.
28 Apr 2023 10:45
Replied by Gr8uncleal on topic Spot the mistake.
Piston orientation, perchance?
I guess it ranks alongside the RD125 parts book, which shows the battery box fitting on the wrong side.
28 Apr 2023 11:03
- asco
Replied by asco on topic Spot the mistake.
I didn’t see it immediately truth be told - and I won’t spill the beans. But yeah some ting is definitely amiss …
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
28 Apr 2023 13:19
- 19stuberd
Replied by 19stuberd on topic Spot the mistake.
Is this immediately obvious to the layperson?
The only thing I can think of, not being super familiar with the mechanism, is that there's nothing locating the piston rod to the crankshaft in the transverse direction i.e. it can slide up and down the crankshaft (it wouldn't, because of the piston being held in place by the bore, but it could still move in a way that's not intended)
Also piston direction looks right to me I think?
28 Apr 2023 13:51
- run103
Replied by run103 on topic Spot the mistake.
piston is backwards
28 Apr 2023 13:56
Replied by RT325 on topic Spot the mistake.
pissing tin back ta front without looking hard. maybe drew it that way as can't show the holes other way around.
Just put the cylinder on backwards that'd fix it.
- Pedalcrazy
Replied by Pedalcrazy on topic Spot the mistake.
Maybe for a twin carb prototype
29 Apr 2023 06:22
