1973 DT3 Lighing, wiring, battery and voltage questions
  • bhepp15
I recently purchased my first enduro which is a 1973 DT3. The bike does not have a battery, the front headlight is missing but the wiring is still there no blinkers, and no tail lights. Basically nothing but a bunch of wires everywhere. The electrical is my biggest problem with the bike as everything else works so it's mostly just maintenance. I have many questions about this and am looking for some help and opinions.
My problem is that I don't necessarily like the looks of the original lights, they are a little bulky for me. But when looking for a better style of light I find that they are all 12V bulbs. Is there any way to run 12V lights on a 6V battery reliably? I also have looked into converting the whole bike to 12V but that is expensive and may be overkill. I am just not quite sure what to do as I need lights and at least blinkers on the back. Any input would be great.
-Brock
17 Dec 2020 11:37 #1
You can put any lighting system on it you want, and then change the bulbs to 6v bulbs. For instance, a 12v 1157 bulb is a 6v 1154. Fits the same tail light socket.
17 Dec 2020 12:46 #2
  • bhepp15
Does anybody know what is going on here? I do not know really anything about the wiring but this just doesn't look right to me. I am not sure what I need to get the lights on this bike again.
Last edit: 17 Dec 2020 13:38 by bhepp15.
17 Dec 2020 13:38 #3
Find the wiring diagram in the Tech Library above in the toolbar, and the it's all color coded. If you buy turn signals, they will be a certain color (in the diagram). Tail light will be another color. Headlight is obviously the tri-plug at the top. And so on...
You can do it.
17 Dec 2020 14:10 #4
Try octane lighting on the net they have 5and 3.4 LED headlights that work and fit the bucket and you can get LED signal lights everywhere and then install a 6 volt regulator and it will work beautifully.
Doug
17 Dec 2020 14:53 #5
  • bhepp15
Thank you both so much, I don't know what I would do without this forum haha. Run103, if I make all of the lights LED can I run one 6V regulator off the battery or would I need a regulator for each light?
17 Dec 2020 16:00 #6
I run a regulator and no battery. I cant keep them from either cooking the acid out or vibrating it out so I do not use one All I have is tail light and brake light and headlight with High low We do not need signal lights here in Sask Canada They do like you to have a horn though. You can do signal lights with the 6 volt regulator and they work fine . I wish I could find a no maintenance battery for these bikes but I havn't yet. The lead acid works just not very long.
Doug
17 Dec 2020 16:06 #7
On a DT3, the production date will likely be before 1/1/73... (sticker on steering head).
If so, technically in the US you didn't need to have turn signals. Some states are different though.
17 Dec 2020 16:15 #8
  • bhepp15
So what I gather is that in order to have turn signals I need a battery but if I just want lights and brake lights I just need a regulator? Also, I found this 6V battery has anyone used one of these?
18 Dec 2020 11:31 #9
Lithium Ion can be a problem for these old electrical systems. The MotoBatt MBT6N4 is what I have in my DT3 and RT3 regular riders. Some are 5 years old.
The following user(s) Liked this Post: apex
18 Dec 2020 12:02 #10
