Good clutch plates
  • willlgord
  • willlgord's Avatar Topic Author
Good clutch plates was created by willlgord
I need a good set of friction plates for my at1 vintage race bike. I put a 175 reed cylinder on it that’s been ported and it runs really strong, I’ve been struggling to get the clutch slippage under control. I’ve put new eBay plates on it, added an extra metal plate, sandblasted all the metal plates to rough them up and shimmed the springs (which measured within specs) another .040”. I only have a problem when you really get on it, most of the time it’s ok. I see that vesrah-209 plates are recommended but can’t find them anywhere. The eBay plates were pretty cheap, around $30 so I’m not terribly surprised.
Last edit: 09 Dec 2020 18:46 by willlgord.
09 Dec 2020 18:43 #1
Replied by MarkT on topic Good clutch plates
Barnett plates are known to grab very well.
09 Dec 2020 19:31 #2
Replied by Schu on topic Good clutch plates
Maybe you're just not hooking up. Are you roosting the guy behind you when it slips? :ROFLOL
The following user(s) Liked this Post: RT360Fan
Last edit: 10 Dec 2020 09:22 by Schu.
10 Dec 2020 09:21 #3
Replied by RT360Fan on topic Good clutch plates
I thought of this too. A month or so ago I was on a ride, sort of felt like my clutch was slipping. Reality was the rear tire was 'floating' over the loam and spraying/roosting the guy behind me. Feels like the rear end is dancing; Full Tilt Boogie.
I use EBC clutch plates, they seem fine.
Last edit: 10 Dec 2020 10:44 by RT360Fan.
10 Dec 2020 10:03 #4
Replied by Pillsbury on topic Good clutch plates
I use the Barnett Kevlar plates. Night & day from stock
1970 DT1-C Street tracker
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1966 Triumph Tiger Cub
1947 Mustang
1974 Suzuki TC185
10 Dec 2020 15:12 #5
Replied by JayB on topic Good clutch plates
I have had good luck with Barnett, too. I recommend Barnett springs, too because they have a higher spring rate than stock.
You can try using Yamaha 401-16321-00 friction plates if you get rid of the rubber rings underneath the frictions. That will give you more surface area with the steel clutch plates, which could help especially with stronger springs.
10 Dec 2020 16:02 #6
I would caution against getting a later superseded number that the 401- number goes to!
10 Dec 2020 16:12 #7
  • willlgord
Replied by willlgord on topic Good clutch plates
Thanks for the suggestions, my clutch is definitely slipping.....not roosting! It’s time to get ready the bike ready for the 2021 race season, first race is in the middle of March. I’ve got a couple other things to sort out but nothing serious.
10 Dec 2020 18:01 #8
Here is a picture of the original Yamaha replacement part for an AT1, which has space for the rubber ring underneath:
Versus the 401-16321-00 which was used on early MX and YZ 125s, which has no room for the rubber ring:
Hopefully the difference in friction area is apparent.
The following user(s) Liked this Post: MarkT, willlgord
11 Dec 2020 06:09 #9
The 537-16321-00 are still available from Yamaha. I bought a few and will report back if they fit in the 100,125 and 175s. Here are pictures:
The following user(s) Liked this Post: willlgord
12 Dec 2020 17:48 #10
